1. Accessing Pabbly Connect for Your WhatsApp AI Assistant
To build a WhatsApp AI Assistant for Wedding Planners, the first step is accessing Pabbly Connect. Begin by navigating to the Pabbly website and selecting the Pabbly Chatflow application.
If you are a new user, click on “Sign Up for Free”. Existing users can simply sign in. Once logged in, you can access all Pabbly applications, including Pabbly Chatflow, which is essential for setting up your WhatsApp AI Assistant.
2. Creating Your AI Assistant with Pabbly Connect
After accessing Pabbly Chatflow, you will see the dashboard. Here, you can create your AI assistant by clicking on the “Add” button under the AI Assistant section. This is where Pabbly Connect facilitates the integration of your WhatsApp number.
- Click on the “Add” button to create a new assistant.
- Enter a name for your assistant.
- Select the instruction type as “AI agent” from the dropdown.
Once you select the instruction type, basic instructions will be updated automatically. This setup is crucial as it defines how your assistant will interact with customers.
Configuring the AI settings is essential for your WhatsApp AI Assistant’s performance. In this step, you will set parameters such as temperature and select the AI provider. Here, Pabbly Connect integrates with OpenAI to enhance the assistant’s capabilities.
To configure:
- Set the temperature to 0.4 for focused responses.
- Select OpenAI as your AI provider.
- Input your OpenAI API key to connect.
After entering the API key, click on the “Connect” button to save your settings. This integration is critical for enabling intelligent responses from your assistant.
4. Customizing Your Assistant’s Interface with Pabbly Connect
Customizing the interface of your WhatsApp AI Assistant is the next vital step. Using Pabbly Connect, you can adjust various settings to enhance customer interaction. This includes setting up header and footer messages.
To customize your assistant:
- Add a header message with a maximum of 60 characters.
- Set initial messages that customers will see when they start a chat.
- Choose the appearance settings such as light or dark mode.
Once you have customized these settings, your assistant will be visually appealing and ready for customer interactions.
5. Activating Your AI Assistant in Pabbly Connect
The final step is activating your AI assistant. This is where Pabbly Connect truly shines by allowing you to assign your assistant to specific WhatsApp contacts or lists.
To activate your assistant:
- Enable the assistant by toggling the activation button.
- Select the contact list for assignment.
- Click on the “Save” button to confirm the settings.
After saving, your assistant will be ready to handle customer queries on WhatsApp, making your wedding planning business more efficient.
Building a WhatsApp AI Assistant for Wedding Planners using Pabbly Connect is a straightforward process. By following these steps, you can enhance customer engagement and streamline your operations effectively.
