1. Accessing Pabbly Connect to Create Your WhatsApp AI Assistant
To begin creating your WhatsApp AI assistant, you need to access Pabbly Connect. Open your web browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chat Flow homepage.
Once there, you have options to sign up for free or log in if you are an existing user. If you’re new, click on “Sign Up for Free” to create an account. After signing in, you will see a dashboard where you can access various Pabbly applications. Click on “Access Now” under Pabbly Chat Flow to get started.
2. Creating Your AI Assistant in Pabbly Chat Flow
After accessing Pabbly Chat Flow, you can create your AI assistant. Click on the “Add” button to start. You will be prompted to name your assistant. Once named, click on the add button again, and you will be directed to the flow window.
- Select the instruction type from the drop-down menu.
- Choose custom prompts or predefined examples like AI agent.
- Configure AI settings, including temperature and model.
This process allows you to customize how your assistant will interact with users. You can set parameters like the temperature for creativity and choose the AI model based on your requirements.
In this section, you will configure essential settings for your AI assistant. Start by setting the temperature, which determines the creativity of responses. A lower temperature yields focused answers, while a higher temperature allows for more creative responses.
Next, you will need to input your OpenAI API key. Click on the hyperlink provided to generate a new secret key from your OpenAI account. After creating the key, copy it and paste it into the designated field in Pabbly Connect.
4. Customizing the Assistant Interface
Once your AI assistant is configured, you can customize its interface. This includes adding a header and footer message, which enhances user experience. You can also set a stop keyword that users can type to halt the AI’s responses.
- Add a header message (maximum of 60 characters).
- Specify fallback messages for when the API fails to respond.
- Upload your knowledge source file in plain text format.
These settings ensure that your assistant provides accurate and helpful responses to user queries, making it a valuable tool for your business.
5. Activating and Assigning Your Assistant
After finishing the setup, you must activate your assistant by enabling the button and clicking the save button. This ensures that all your configurations are stored correctly in Pabbly Connect.
To assign your assistant to WhatsApp chats, access the inbox settings. Here, enable auto-reply, select your contact list, and choose the assistant you want to assign. Click save to apply these settings, allowing your assistant to respond to user inquiries automatically.
In summary, this tutorial detailed how to create a WhatsApp AI assistant using Pabbly Connect. By following these steps, you can enhance customer interaction and streamline your business processes effectively.
