1. Accessing Pabbly Chatflow to Create Your AI Agent
To create an AI agent for WhatsApp, you must first access Pabbly Chatflow. Start by logging into your Pabbly account and navigating to the AI Assistant feature.
Click on the “Add AI Assistant” button to begin. You will be prompted to name your assistant; for this tutorial, we will name it “Smart AI Agent”. After naming, click the confirm button to proceed.
2. Setting Up Your AI Agent in Pabbly Chatflow
In this section, you will configure your AI agent settings in Pabbly Chatflow. First, select the type of instructions for your AI assistant. Choose “AI Agent” from the options available.
- Define specific instructions for how your AI should respond.
- Set the temperature to control the creativity of responses; a lower value gives more precise answers.
- Choose OpenAI as your AI provider and select the appropriate version, such as GPT-4o mini.
After setting these options, you will need to input your API Key from OpenAI to establish a connection. This key allows your AI agent to interact with the OpenAI services effectively.
3. Configuring Your API Key in Pabbly Chatflow
To link your OpenAI account with Pabbly Chatflow, you must generate an API Key. Navigate to the API Keys section in OpenAI and click on “Create New Secret Key”.
Once generated, copy the API Key and paste it into the designated field in Pabbly Chatflow. After pasting the key, click on the “Connect” button to ensure that your API Key is saved successfully.
- Ensure your OpenAI account is a paid account to generate the API Key.
- Verify that your API Key is active and properly inserted.
After successfully connecting your API Key, you can proceed to set up additional settings for your AI agent.
4. Training Your AI Agent with Business Data in Pabbly Chatflow
Now that your AI agent is connected, it’s time to train it using your business data. In Pabbly Chatflow, you must upload a knowledge base file that contains all relevant information about your business.
This knowledge base acts as a reference for your AI agent, allowing it to provide accurate and tailored responses. You can create this file using Google Docs or any text application, ensuring it is under 90 MB in size.
- Upload the knowledge base file by clicking on “Add New File” in the knowledge source section.
- Select your file from your device and confirm the upload.
Once the file is uploaded successfully, your AI agent will be trained and ready to assist customers effectively.
5. Finalizing Your AI Agent in Pabbly Chatflow
To finalize your AI agent setup in Pabbly Chatflow, you can customize its interface by adjusting the title, subtitle, and initial message. This customization helps create a friendly user experience.
After making the necessary adjustments, toggle the activation switch to make your AI agent live. Finally, click the “Save Assistant” button to complete the setup process.
- Ensure that all settings are double-checked before saving.
- You can embed this AI agent on your website for broader access.
With these steps, your WhatsApp AI agent is now fully operational and ready to engage with customers using the data you provided.
Using Pabbly Chatflow, you can easily create an AI agent for WhatsApp that utilizes your business data. This tutorial outlined the essential steps to set up and customize your agent effectively.
By following these instructions, you can enhance customer engagement and streamline interactions. Start building your AI agent today with Pabbly Chatflow!
