1. Setting Up Pabbly Connect for Your AI Agent
To build a WhatsApp AI Agent for Returns & Refunds, you first need to access Pabbly Connect. Start by visiting pabbly.com and creating a free account. This platform will serve as the central hub for integrating various applications involved in your AI agent setup.
Once you log in, navigate to the Pabbly Connect dashboard. Here, you can begin the integration process. Ensure you have access to Pabbly Chatbot and OpenAI, as these will be crucial for your AI agent’s functionality.
2. Creating Your AI Agent in Pabbly Chatbot
Next, head over to Pabbly Chatbot, where you will create your AI agent. Click on the “Add AI Assistant” button to start. This is where you will define the parameters for your WhatsApp AI Agent.
  • Choose a name for your assistant.
  • Select the type of instructions for your AI.
  • Set the temperature for response creativity.
After setting these parameters, you will configure the AI response behavior. This involves selecting OpenAI as your AI provider and specifying the API Key, which you can obtain from your OpenAI account.
3. Configuring the OpenAI API Key
To connect OpenAI with Pabbly Connect, you need to enter your API Key. This key is essential for authenticating requests made by your AI agent. Visit your OpenAI account to generate this key if you haven’t done so already.
Copy the API Key and paste it into the corresponding field in Pabbly Chatbot. Once you’ve done this, click on the “Connect” button to establish the connection. A confirmation message will appear, indicating that your API Key has been saved successfully.
4. Uploading Your Knowledge Base
Your AI agent will need a knowledge base to provide accurate responses. In Pabbly Connect, navigate to the knowledge base section and upload a PDF file containing your business information, policies, and FAQs. This file acts as the brain of your AI agent.
  • Ensure the PDF is under 90 MB.
  • Limit images in the PDF to 10 pages.
  • Use Google Docs or similar applications to create your PDF.
After uploading, confirm that the file is correctly linked in the settings. This ensures your AI agent can access the necessary information to assist customers effectively.
5. Finalizing Your WhatsApp AI Agent
With everything set up, it’s time to finalize your WhatsApp AI Agent. In Pabbly Connect, customize the interface of your AI agent, including the welcome message and design options. You can adjust the colors and layout to match your brand.
Once satisfied with the design, activate your AI agent by toggling the activation switch and clicking “Save AI Assistant”. This step ensures that your AI agent is ready to handle customer inquiries regarding returns and refunds.
In this tutorial, we explored how to build a WhatsApp AI Agent for Returns & Refunds using Pabbly Connect, Pabbly Chatbot, and OpenAI. By following these steps, you can create an efficient AI assistant that enhances customer service.
