1. Accessing Pabbly Connect to Create Your Telegram Chatbot
To build a Telegram chatbot using Pabbly Connect, you first need to access the platform. Go to the Pabbly Connect website and sign up for a free account.
Once logged in, you can utilize the Pabbly Connect workflow builder. This tool is essential for creating the automation that will connect your Telegram bot with ChatGPT.
2. Setting Up Your Telegram Bot with Pabbly Connect
After accessing your Pabbly Connect account, the next step is to set up your Telegram bot. Click on the “Add Trigger” button in Pabbly Connect and search for “Telegram Bot”.
  • Select the event as “Set Webhook/Watch Updates”.
  • Connect your Telegram account using the token generated from BotFather.
  • Ensure the bot is added to the desired group and has admin rights.
By following these steps, you will successfully connect your Telegram bot to Pabbly Connect, allowing it to receive messages and respond accordingly.
3. Integrating ChatGPT with Pabbly Connect
Next, you will integrate ChatGPT into your workflow using Pabbly Connect. Add a new action step and search for “OpenAI” to select ChatGPT.
For this integration, you will need to provide your OpenAI API key. Click on “Add New Connection” and follow the prompts to generate your API key from the OpenAI dashboard. Once you have the key, paste it into Pabbly Connect.
4. Mapping User Input for Dynamic Responses
Mapping user input is crucial for your Telegram chatbot to respond dynamically. In your Pabbly Connect workflow, ensure you map the user message from Telegram into the prompt field for ChatGPT.
  • Use a slash to insert the mapped user message dynamically.
  • Ensure your prompt remains consistent while allowing user messages to change.
This setup enables your chatbot to provide tailored responses based on user queries, showcasing the power of Pabbly Connect in integrating various applications seamlessly.
5. Sending Responses Back to Telegram
Finally, you need to send the responses generated by ChatGPT back to the Telegram group. Add another action step in your Pabbly Connect workflow and search for “Telegram Bot” again.
Select the action event as “Send Text Message” and map the chat ID and the response message generated by ChatGPT. This ensures that the replies are sent back to the correct group in real-time, completing the integration.
In this tutorial, you learned how to build a Telegram chatbot using ChatGPT and Pabbly Connect. This integration allows for dynamic responses based on user input, enhancing communication efficiency.
