To start integrating Studio with Pabbly Connect, first visit Pabbly Connect at pably.com. Log in to your Pabbly account to access all applications in one place.
Once logged in, navigate to the Pabbly Studio section by selecting it and clicking on “Access Now”. This interface allows you to create applications without any coding.
2. Creating Your Application in Pabbly Studio
In this section, we will build an application using Pabbly Studio. Start by describing your application in the provided box. For this tutorial, we will create an application called “Crateline” for managing suppliers and purchase orders.
  • Define your application purpose.
  • Outline key functionalities like supplier management and order tracking.
  • Ensure a user-friendly interface.
Once you have described your application, click on “Submit”. This will trigger Pabbly Connect to begin building the application step by step, taking just a few minutes.
3. Managing Orders and Suppliers with Pabbly Connect
After your application is created, you can manage orders and suppliers effectively. Log in to your newly created application to view outstanding amounts owed to suppliers. Each supplier will have a price list from which you can generate purchase orders.
For example, when creating a purchase order, you will:
  • Select items from the supplier’s price list.
  • Enter quantities, and the total will auto-calculate.
  • Submit the order through Pabbly Connect.
This seamless integration ensures that all data is stored correctly and updated in real-time, making order management efficient.
4. Tracking Deliveries and Payments in Pabbly Connect
Tracking deliveries and payments is crucial for maintaining supplier relationships. With Pabbly Connect, you can easily log deliveries and payments within your application.
For instance, when goods arrive, you can mark them as received, either partially or fully. This action updates the status of your purchase order automatically, reflecting accurate inventory levels.
To record payments, simply enter the amount due and add a bank reference. Pabbly Connect will adjust the outstanding amounts and update the order status to “Paid” seamlessly.
5. Using AI Tools with Pabbly Connect
Integrating AI tools like Claude and ChatGPT with Pabbly Connect enhances your application’s functionality. You can connect these tools through the MCP (Multi-Channel Platform) for advanced features.
To do this, paste the provided address into your AI tool. This allows you to create and modify applications using simple commands, without consuming your AI tool’s credits.
Additionally, Pabbly Connect handles backend processes like database management and version control, ensuring smooth operation and easy recovery of earlier versions of your application.
This tutorial demonstrated how to integrate Studio, Pabbly, Pabbly Studio, Claude, and ChatGPT using Pabbly Connect. By following these steps, you can streamline supplier management and enhance your application’s capabilities effectively.
