To automate your WhatsApp bookings, start by accessing Pabbly Connect. Open a new tab and navigate to the Pabbly Chartflow website. If you’re new, click on the ‘Sign Up Free’ option to create an account. Existing users should click on ‘Sign In’. This initial step is crucial to utilize the powerful features of Pabbly Connect.
Once logged in, you will land on the Pabbly Chartflow dashboard. Here, you can manage your WhatsApp numbers and set up your chatbot. Ensure that you have added your WhatsApp number, as this is essential for the integration process. The next step involves creating a new flow by clicking on the ‘Add Flow’ button, which allows you to initiate your WhatsApp booking bot.
2. Creating Your WhatsApp Chatbot with Pabbly Connect
In this section, you will create your WhatsApp chatbot using Pabbly Connect. After adding a new flow, give it a descriptive name like “Smart WhatsApp Booking Bot”. Use the active toggle to ensure your flow is active. Remember, if the toggle is inactive, your bot won’t function.
- Click on the ‘Trigger Event’ option.
- Select ‘Template Selected’ as your trigger event.
- Choose the ‘Event Update’ template.
After selecting the template, you can customize the options presented to users. The bot will offer them choices like viewing event details or booking tickets, making the process interactive and user-friendly. This setup is essential for engaging users effectively through Pabbly Connect.
3. Setting Up Ticket Options in Pabbly Connect
Now, you will configure the ticket options for your WhatsApp booking bot using Pabbly Connect. After the initial template is set, drag a line from the ‘Book Now’ button to a list pattern that displays ticket types. This list will include options such as “VIP Access”, “General Admission”, and “Group Pack”.
Make sure to customize the ticket types according to your needs. For instance, you can add pricing information alongside each ticket type. This customization helps users make informed decisions. After setting up the ticket list, link it back to the previous steps to ensure a smooth flow of information.
4. Collecting User Information through Pabbly Connect
In this step, Pabbly Connect will help you collect essential user information. Once a user selects a ticket type, the bot will prompt them for their full name, email address, and the number of tickets. To do this, use the ‘Ask Question’ button to create interactive prompts for each piece of information.
- First, ask for the user’s full name.
- Second, request their email address.
- Lastly, inquire about the number of tickets they wish to book.
Ensure that each question is linked to a corresponding contact custom field. This setup allows Pabbly Connect to dynamically capture user inputs, making the interaction seamless and efficient. After gathering all necessary information, the bot can summarize the booking details for the user.
5. Finalizing the Booking Process with Pabbly Connect
After collecting user information, Pabbly Connect will generate a summary message that includes all the details provided by the user. This summary will thank the user and confirm their booking request. Use the ‘Text’ button to create a dynamic response that incorporates user-specific data.
For example, your message could read: “Thank you, {Full Name}, for booking {Quantity} tickets for {Ticket Type}. Our team will contact you shortly.” This personalized touch enhances user experience and reinforces engagement. Finally, save your flow to ensure all configurations are updated and active.
In conclusion, using Pabbly Connect to automate your WhatsApp booking process can significantly streamline customer interactions. By following this tutorial, you can create an effective booking bot that operates seamlessly without manual intervention. Start automating your WhatsApp communications today!
