1. Introduction to Pabbly Connect for WhatsApp Integration
Pabbly Connect is an essential tool for building a Smart WhatsApp Auto-Responder Bot. This integration automates customer interactions via WhatsApp, enhancing user experience.
To get started, sign up for Pabbly Connect and access the dashboard. From here, you can create workflows that link WhatsApp with other applications seamlessly.
2. Creating Your Chatbot Flow with Pabbly Connect
In this section, we will create a chatbot flow using Pabbly Connect. Begin by selecting the ‘Create New Flow’ option in the Pabbly Chatbot dashboard.
  • Click on the ‘Flow Builder’ option.
  • Name your flow appropriately.
  • Select ‘Trigger Event’ as the starting point.
Once your flow is set, choose the appropriate template for your bot. Pabbly Connect allows you to customize templates to suit your specific needs.
3. Adding List Blocks to Your Chatbot
Now, let’s enhance the chatbot by adding list blocks using Pabbly Connect. This feature will allow customers to select from various product categories.
  • Add a list block to your flow.
  • Enter a header and message for the list.
  • Include multiple items for selection.
After adding the list items, connect them to the relevant sections of your flow. This allows the chatbot to respond appropriately based on user selections.
4. Setting Up Custom Fields for User Input
Setting up custom fields is crucial for gathering user information through Pabbly Connect. This feature helps personalize the customer experience.
To set custom fields, navigate to the settings in your flow. Here, you can define what information you want to collect, such as names and contact details.
Make sure to connect these fields to the relevant questions in your flow. This ensures that the bot collects the necessary information seamlessly.
5. Finalizing Your WhatsApp Auto-Responder Bot
Finally, you need to finalize your chatbot flow using Pabbly Connect. Review the entire flow to ensure that all connections are correct.
Once everything looks good, click the ‘Save’ button to store your settings. Your Smart WhatsApp Auto-Responder Bot is now ready to assist customers!
Test the bot to see how it interacts with users and make adjustments as necessary. This ensures a smooth customer journey from start to finish.
In this tutorial, we explored how to build a Smart WhatsApp Auto-Responder Bot using Pabbly Connect. By following the steps outlined, you can enhance customer interactions and streamline order processes effectively.
