To begin integrating WhatsApp AI with Pabbly Connect, first, you need to access the Pabbly Connect platform. Navigate to the official Pabbly website and log in to your account. If you’re a new user, you can sign up for a free account which offers 100 free credits every month.
Once logged in, you will find options to create new workflows. Pabbly Connect acts as a bridge for connecting various applications like WhatsApp, API, and GST. This means you can automate responses and manage queries effectively through WhatsApp.
2. Creating Your WhatsApp AI Assistant Using Pabbly Connect
Now that you are in Pabbly Connect, the next step is to create your WhatsApp AI Assistant. Select the instruction type as “AI agent”. This allows you to set up the AI that will handle customer queries. You can modify the instructions according to your business needs.
  • Choose the AI model you want to use.
  • Set the creativity level (temperature) for responses.
  • Enter your API key from the OpenAI API key page.
After configuring these settings, click on the connect button to save your AI assistant settings. Pabbly Connect ensures that your assistant is ready to respond to queries automatically.
3. Configuring AI Assistant Settings in Pabbly Connect
Next, you need to configure the settings for your AI assistant. This includes customizing the header and footer messages, setting stop keywords, and defining retry attempts. These settings help to refine how your AI assistant interacts with users.
  • Set a stop keyword to halt the assistant when needed.
  • Define the number of retry attempts for unanswered queries.
  • Upload a knowledge base in .txt or PDF format for reference.
These configurations are crucial for ensuring that your AI assistant operates smoothly. Pabbly Connect allows for easy adjustments to these settings, making it simple to tailor the assistant to your specific requirements.
4. Styling and Embedding Your AI Assistant with Pabbly Connect
Once your AI assistant is configured, it’s time to style it. Choose the theme, adjust the colors, and set profile pictures that match your brand. This visual customization is important for providing a consistent user experience.
To embed your AI assistant into your business, click the embed button to get the script code. You can then paste this code into your website or application. Pabbly Connect makes it seamless to integrate your assistant across different platforms.
5. Enabling AI Auto Replies for WhatsApp with Pabbly Connect
The final step is to enable AI auto replies for WhatsApp. Go to the inbox settings in Pabbly Connect and enable the AI auto replies feature. This ensures that your AI assistant can respond to all customer inquiries automatically.
You can select specific contacts or enable the assistant for all contacts. This flexibility allows you to manage customer interactions effectively. Pabbly Connect simplifies this process, enabling you to set up a fully automated communication channel.
In this tutorial, we explored how to integrate WhatsApp AI with Pabbly Connect. By following these detailed steps, you can automate your customer interactions effectively and provide quick responses to queries. Start using Pabbly Connect today to enhance your business communication.
