To begin creating your WhatsApp AI chatbot, you need to access Pabbly Connect. Start by entering the URL pav.com/chartflow in your browser. This will direct you to the Pabbly Chatflow homepage.
If you are a new user, click on the “Sign Up for Free” button to create your account. Existing users can simply sign in. Once logged in, navigate to the Pabbly Chatflow dashboard to begin your integration process.
2. Creating Your AI Assistant in Pabbly Connect
Once you are in the Pabbly Chatflow dashboard, the next step is to create your AI assistant. Click on the “AI Assistant” feature. Here, you will see options for existing assistants and an “Add” button to create a new one.
  • Click the “Add” button to start creating your assistant.
  • Choose a name for your assistant and click “Add” again.
  • Select the instruction type, such as “AI Agent” from the dropdown menu.
After selecting the instruction type, configure the AI settings. Set the temperature for responses, select the AI model, and input your OpenAI API key. This key connects your assistant to the OpenAI model, allowing it to generate responses based on user queries.
In this section, you will configure the specific settings for your WhatsApp AI assistant. Start by setting the temperature, which determines how focused or creative the responses will be. A lower value like 0.4 will yield more focused answers.
Next, input your OpenAI API key. To obtain this key, click the hyperlink provided in the settings and follow the prompts to create a new secret key. Once you have copied the key, paste it into the designated field in Pabbly Connect.
  • Enable the header and footer messages by toggling the respective buttons.
  • Add stop keywords to allow users to halt the assistant’s responses, such as “human”.
  • Specify fallback messages for instances when the API fails to respond correctly.
This configuration ensures that your assistant can handle various scenarios effectively, providing a seamless user experience.
4. Finalizing Your Assistant Settings in Pabbly Connect
After configuring the AI settings, you can finalize your assistant’s interface. Add your brand name and any initial messages that users will see when they start a conversation. You can also customize the appearance of your assistant by choosing colors and styles.
Once you have completed these settings, activate your assistant by clicking the “Save” button. This step is crucial as it ensures that all your configurations are stored correctly in Pabbly Connect.
  • Upload any relevant images for your assistant’s profile.
  • Review all settings to ensure accuracy before saving.
With these steps, your WhatsApp AI assistant is now fully configured and ready to respond to customer queries.
5. Assigning Your Assistant to WhatsApp Chats via Pabbly Connect
To assign your newly created assistant to your WhatsApp chats, navigate to the inbox settings in Pabbly Connect. Here, you can enable auto-reply for your contacts.
Scroll down to the AI auto-reply settings, where you will select the contact list for which the assistant will be active. Choose the assistant you created earlier and click “Save” to apply these changes.
  • You can also assign the assistant to individual chats by selecting a specific WhatsApp conversation.
  • Turn on the assistant button for that chat and select the appropriate assistant.
This way, your assistant will be able to respond to customer messages automatically, enhancing your business’s communication efficiency.
In this tutorial, we explored how to create a WhatsApp AI chatbot using Pabbly Connect. By following these steps, you can automate responses to customer queries seamlessly. Enhance your business communication with this powerful integration tool!
