1. Creating an AI Assistant with Pabbly Chatbot
To create an AI assistant for booking services, you first need to access the Pabbly Chatbot. Start by clicking on the “Add AI Assistant” button. This action will initiate the setup process.
Once you click the button, provide a descriptive name for your assistant. After naming, select the instruction type as “AI Agent”. This instruction will guide how the AI behaves and responds to customers.
2. Configuring AI Settings in Pabbly Connect
In this section, you will configure the AI settings using Pabbly Connect. Adjust the temperature setting, which controls the creativity of responses. A lower temperature results in more precise answers, while a higher temperature allows for more creative responses.
- Set temperature to 0.5 for balanced responses.
- Choose OpenAI as your AI provider.
- Select the appropriate OpenAI version, like GPT-4o mini.
Next, you need to input your OpenAI API key. To obtain this key, visit your OpenAI API keys page and create a new secret key. Copy this key and paste it into the designated field in Pabbly Connect.
3. Setting Up the Knowledge Base for Your Assistant
The knowledge base is crucial for your AI assistant to provide accurate responses. In this step, upload a knowledge base file using Pabbly Connect. This file should contain all relevant information about your services, prices, and procedures.
To create a knowledge base, you can use Google Docs or any other text editor to format the information. Ensure the file is in .txt or .pdf format and does not exceed 90MB. Once your file is ready, upload it by clicking on the “Add New File” option.
- Ensure the file contains all necessary details about your business.
- Upload the file from your device to Pabbly Connect.
After uploading, select the file and click the “Insert” button to finalize the setup. This allows your AI assistant to use this knowledge base to respond to customer inquiries effectively.
4. Designing Your AI Assistant’s Interface
With the knowledge base set up, you can now design your AI assistant’s interface using Pabbly Connect. Customize elements such as the title, subtitle, and introductory message. This personalization enhances user experience.
Make sure to adjust the visual elements, including colors and styles, to match your business branding. Once satisfied with the design, activate the assistant by clicking the activation button.
Finally, save your AI assistant settings to ensure all changes are applied. This step is crucial for the assistant to function correctly and provide seamless service to clients.
5. Final Setup and Testing of Your AI Assistant
The last step involves finalizing the setup for your AI assistant in Pabbly Connect. Navigate to the settings section and enable the option that allows the AI assistant to respond to conversations.
Ensure that you select the appropriate contact list for your assistant to interact with. After making these selections, save your automatic response rules.
- Check that the AI assistant is enabled for all relevant contacts.
- Test the assistant to ensure it responds as expected.
Once everything is set up, you can start using your AI assistant to handle booking inquiries automatically. This setup ensures that your assistant is available 24/7 to assist customers without delay.
In conclusion, this tutorial demonstrates how to leverage Pabbly Connect to integrate various applications like Pabbly, Pabbly Chatbot, API, PDF, OpenAI, Google, and Google Docs. By following these steps, you can create an efficient AI assistant to handle customer bookings seamlessly.
