1. Accessing Pabbly Chatflow to Create Your Chatbot
To start creating a WhatsApp chatbot, first, you need to access Pabbly Chatflow. Open your web browser and go to www.pabbly.com/chatflow. If you are a new user, click on “Sign up for free” to create an account and receive 100 free credits monthly.
For existing users, simply click on “Sign in” at the top right corner. Once you are logged in, you will see the dashboard where you can manage your chatbots and settings. Make sure to connect your WhatsApp number by clicking on “Add WhatsApp Number” and following the prompts.
2. Creating Your AI Assistant in Pabbly Chatflow
After logging into Pabbly Chatflow, navigate to the AI Assistant section. Click on “Create AI Assistant” to start building your WhatsApp chatbot. Name your assistant appropriately, for example, “Market Pulse Capital.” This will serve as the identity of your chatbot.
- Select the instruction type as “AI Agent”.
- Set the AI temperature to 0.7 to balance creativity and focus.
- Connect your OpenAI API key to enable AI responses.
After setting these options, you can customize the assistant’s responses and behavior. This is crucial for tailoring the chatbot to your specific stock market queries.
3. Uploading Your Knowledge Base for Effective Responses
To ensure your Pabbly Chatflow AI assistant can provide accurate responses, upload a comprehensive knowledge base. Click on the “Knowledge Source” option and select the file you have prepared. This file should contain all relevant information about your stock market services.
Make sure your knowledge base is detailed, including:
- Company details and services offered.
- Common queries and their answers.
- FAQs related to stock market investments.
Once uploaded, your AI assistant will be able to reference this information while responding to user queries, ensuring that answers are accurate and helpful.
4. Customizing the Assistant Interface in Pabbly Chatflow
Next, you can customize how your Pabbly Chatflow assistant appears to users. Change the theme, header, and footer messages to match your branding. You can also adjust the assistant’s shape and colors to enhance user experience.
For example, you can:
- Set the theme mode to dark or light.
- Upload a profile picture for your assistant.
- Add initial greeting messages for users.
These customizations will help create a more engaging interaction for users reaching out via WhatsApp.
5. Enabling Auto Replies and Assigning AI Assistant
Finally, to maximize efficiency, enable auto-replies in Pabbly Chatflow. This feature allows your AI assistant to respond to all incoming messages automatically. Navigate to the settings and toggle the “Enable AI Auto Replies” option.
To assign your AI assistant to specific contacts or groups, select the appropriate settings and save your choices. This ensures that all relevant queries are handled by your AI assistant, streamlining your communication process.
By following these steps, you can effectively automate your WhatsApp interactions, improving response times and user satisfaction.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Chatflow. By following the steps outlined, you can automate responses and enhance your stock market business communication.
