1. Accessing Pabbly Connect for Your AI Agent
To build a Smart AI Agent using Pabbly Connect, start by visiting the Pabbly Connect website. This platform allows you to integrate various applications seamlessly, including Google Sheets and Google Gemini. If you are a new user, sign up for a free account to access 100 free tasks.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow by selecting the “Create Workflow” option. This sets the stage for connecting Google Sheets with Google Gemini to generate YouTube titles automatically.
2. Setting Up the Integration in Pabbly Connect
In this section, you will set up the integration between Google Sheets and Google Gemini using Pabbly Connect. Start by using the Quick Builder option to define your workflow. Enter your request, specifying that you want to connect Google Sheets to Google Gemini.
- Select “Google Sheets” as the trigger application.
- Choose the “New Row” event to trigger the workflow.
After configuring the trigger, go to your Google Sheets and install the Pabbly Connect Webhooks add-on. Refresh your spreadsheet to complete the installation. Return to the extensions menu, select Pabbly, and then choose the “Initial Setup” option to paste the webhook URL.
3. Testing the Webhook Connection
Now that you have set up the webhook, it’s time to test the connection using Pabbly Connect. In Google Sheets, navigate back to the Pabbly Connect Webhooks menu and select the “Send on Event” option. This prepares the sheet to capture data as you enter new ideas.
Enter a new YouTube video idea in your spreadsheet. For instance, type “Trending streetwear fashion styles inspired by celebrities”. After entering the idea, refresh the sheet to see if the webhook captures the response. You should see the description captured in your Pabbly Connect dashboard.
4. Generating Title Ideas with Google Gemini
With the webhook successfully tested, you can now generate title ideas using Pabbly Connect and Google Gemini. Set up a new action step in your workflow to connect to Google Gemini. You will need to provide the API key from your Google Gemini account.
- Navigate to the API keys section in Google Gemini.
- Generate a new API key and copy it.
- Paste the API key into Pabbly Connect when prompted.
Next, define the prompt that Google Gemini will use to generate titles. For example, you might say, “You are a viral YouTube title expert and a fashion content strategist.” This prompt helps Gemini understand the context and generate relevant titles.
5. Updating Google Sheets with Generated Titles
After generating title ideas, the final step is to update your Google Sheets with the results using Pabbly Connect. Create another action step to connect back to Google Sheets. Select the spreadsheet and specify the range where you want the title ideas to be updated.
For example, if you want to update the titles in column B, map the data from the previous step to this column. Click on the “Save and Send Test Request” button to update your spreadsheet. Once completed, you should see the 20 title ideas populated in your Google Sheets automatically.
In this tutorial, you learned how to build a Smart AI Agent using Pabbly Connect and Google Gemini. This setup allows you to generate SEO-friendly YouTube titles effortlessly. With this integration, you can streamline your content creation process and enhance your productivity.
