To start integrating applications like Just, Now, and others using Pabbly Connect, open your browser and go to pabbly.com/connect. Here, you can sign up for a free trial, allowing you to explore the platform’s capabilities.
After signing up, you will be directed to the Pabbly Connect dashboard. Click on the “Create Workflow” button and choose to create from scratch. Name your workflow, for example, “AI Slack Board,” and click the create button to open the workflow builder.
In this section, you will set up a trigger for your workflow using Pabbly Connect. Click on the “Add Trigger” button, select the trigger as “Schedule,” and set the event to “Schedule Workflow.” Choose how often you want this workflow to run, such as daily.
  • Select the preferred date and time for the workflow to start.
  • Set the frequency of the workflow execution.
Once you have configured the schedule, you can proceed to generate content using another application. This is where Pabbly Connect shines, allowing seamless integration with various services.
3. Generating Content with Gemini via Pabbly Connect
Next, you will add an action step to generate content. Click on “Add New Action Step” and select “Gemini” as the action application. For the event, choose “Generate Content” and click “Connect.”
Make sure to enter your API key from Google AI Studio to connect Gemini with Pabbly Connect.
To obtain the API key, navigate to Google AI Studio, find the “Get API Key” section, and create a new key. After copying the key, paste it into your workflow. Once connected, you can input the content prompt that you wish to generate.
4. Sending Generated Content to Slack Using Pabbly Connect
Once you have the content generated, the next step is to send it to Slack. Search for Slack in the action application list and select it. Choose the event as “Send Channel Message” and click “Connect.”
You will need to specify the token type, either user or bot. Ensure that your Slack account is logged in and select the appropriate workspace.
  • Select the channel where the message will be sent.
  • Map the generated content from the previous step to be sent as a message.
After configuring the message details, click on the “Save and Send Test Request” button. This will send the generated message to your chosen Slack channel, confirming that Pabbly Connect has successfully integrated these applications.
5. Conclusion: Automate Your Workflow with Pabbly Connect
By following these steps, you can effectively integrate Just, Now, See, Gemini, API, Once, Okay, Name, Like, Google, Slack, Make, AI Slack, and Google Gemini using Pabbly Connect. This tutorial demonstrated how to automate your workflow, enhancing productivity and efficiency.
With Pabbly Connect, you can streamline your processes and ensure that your team receives timely updates on Slack. Start exploring these integrations today to maximize your workflow automation!
