1. Accessing Pabbly Connect for Your WhatsApp Bot
To build a simple WhatsApp inquiry bot, you first need to access Pabbly Connect. This platform enables seamless integration between various applications, streamlining the process for small businesses.
Once you log into Pabbly Connect, navigate to the dashboard where you can start creating your workflow. This will serve as the foundation for your WhatsApp inquiry bot.
2. Setting Up Pabbly Chatbot for Inquiry Responses
Next, you will set up Pabbly Chatbot to handle customer inquiries. This step is crucial as it allows your bot to respond to frequently asked questions automatically.
  • Create a new workflow in Pabbly Chatbot.
  • Name your workflow accordingly.
  • Select a trigger event to initiate the bot.
After setting up the workflow, you can customize your bot’s responses based on customer inputs. This customization is made easy with the features provided by Pabbly Connect.
3. Designing the Chat Flow with Pabbly Chat Flow
Now, it’s time to design the chat flow using Pabbly Chat Flow. This tool allows you to create an interactive experience for your users.
Start by adding various nodes to your chat flow. You can include questions that the bot will ask customers, such as their name, contact number, and medication details. This information is essential for providing personalized responses.
  • Add nodes for customer inquiries.
  • Integrate fields for personalized responses.
  • Ensure the flow is logical and user-friendly.
Using Pabbly Connect, you can link these nodes to create a cohesive chat flow that enhances user engagement.
4. Finalizing Your Inquiry Bot and Activating It
Once your chat flow is designed, you need to finalize the inquiry bot. This involves reviewing all the responses and ensuring everything is set correctly.
Activate your bot in Pabbly Connect to make it operational. This step is crucial as it allows your bot to start interacting with customers promptly.
Don’t forget to test your bot to ensure it behaves as expected. You can simulate customer inquiries to see how well your bot responds.
5. Broadcasting Messages Using Pabbly Chatbot
To reach a larger audience, utilize the broadcasting feature in Pabbly Chatbot. This allows you to send messages to multiple contacts simultaneously.
Follow these steps to set up your broadcast:
  • Access the broadcast feature in Pabbly Chatbot.
  • Create a new broadcast campaign.
  • Select the template for your message.
Using Pabbly Connect, you can automate this process, ensuring your messages reach your audience effectively and efficiently.
In summary, using Pabbly Connect, you can effortlessly create a simple WhatsApp inquiry bot tailored for small businesses. This integration enhances customer interaction while streamlining operations.
