1. Accessing Pabbly Connect for WhatsApp Chatbot Integration
To create a WhatsApp chatbot, first, you need to access Pabbly Connect. This platform enables seamless integration between various applications, allowing you to automate responses to customer queries on WhatsApp.
Begin by visiting the Pabbly website. If you already have an account, simply sign in. For new users, you can sign up for free and receive 100 credits monthly to explore Pabbly Connect’s features.
2. Setting Up Pabbly Chatflow for Your WhatsApp Chatbot
Once logged into Pabbly Connect, navigate to the Pabbly Chatflow dashboard. Here, you can manage your WhatsApp number and settings. To connect your WhatsApp account, click on the “Add WhatsApp Number” option.
  • Choose the preferred method to connect your WhatsApp account.
  • You can also use a manual token if needed.
This integration allows your chatbot to send automated replies to incoming messages, enhancing customer interaction without manual effort.
3. Creating Your AI Agent in Pabbly Chatflow
Next, you will create an AI agent within Pabbly Connect. Click on the “AI Agent” option on the left sidebar of the dashboard. Here, you can manage existing agents or create a new one.
To create a new AI agent, click on “Create AI Assistant” and name it (e.g., “SAS Chatbot”). Select the instruction type as AI agent, which will automatically populate the necessary fields. You can customize these instructions based on your needs.
  • Set the creativity level of responses through the temperature setting (0 for focused, 1 for creative).
  • Enter your OpenAI API key to connect the AI model.
Once configured, your AI agent will be capable of responding to various queries from users effectively.
4. Configuring Response Settings and Knowledge Base
In this section, you will set up response settings for your AI agent using Pabbly Connect. You can add header and footer messages that users will see during interactions. Make sure to toggle on these settings to enable them.
Additionally, you can upload a knowledge base file that contains essential information about your business. This file will guide the AI in providing accurate responses to user queries.
  • Ensure your PDF file is up to 10 pages and contains relevant images.
  • The knowledge base should cover company information, services, and FAQs.
By setting these configurations, your AI agent will be well-prepared to assist customers effectively.
5. Assigning the AI Assistant to Contacts in Pabbly Connect
Finally, to make your AI assistant operational, you need to assign it to specific contacts or groups using Pabbly Connect. Open the inbox settings and navigate to the AI auto-reply settings. Here, you can enable the feature and select the AI assistant you created.
To assign the assistant to multiple contacts, you can select all contacts or specific groups and save the rules. This automation allows your AI assistant to handle queries efficiently without manual intervention.
Once set up, your AI assistant will be ready to respond to customer inquiries on WhatsApp effectively, streamlining your business operations.
In this tutorial, we explored how to create a WhatsApp chatbot using Pabbly Connect. By following the detailed steps, you can automate customer interactions and enhance your business efficiency.
