To start integrating Pabbly with Pabbly Chatbot and OpenAI API, you first need to access Pabbly Connect. This platform allows you to automate your workflows seamlessly, enabling automatic responses on WhatsApp.
After logging into your Pabbly account, navigate to the Pabbly Connect dashboard to begin setting up your automation. Here, you can create workflows that connect various applications, including Pabbly, Pabbly Chatbot, and OpenAI API.
2. Creating Your AI Assistant in Pabbly Chatbot
Next, you will create an AI assistant using Pabbly Chatbot. This assistant will handle customer inquiries automatically on WhatsApp. Click on the “Add AI Assistant” button to get started.
- Choose a name for your assistant, e.g., “E-commerce AI Assistant”.
- Select the type of instructions for your assistant, such as “AI Agent”.
- Set the temperature level to control the creativity of responses.
Once these settings are configured, you can proceed to select OpenAI as your AI provider. This integration will allow your assistant to generate intelligent responses based on customer queries.
3. Setting Up OpenAI API Key in Pabbly Connect
After configuring your assistant, the next step involves setting up the OpenAI API key through Pabbly Connect. This key connects your assistant to OpenAI’s capabilities, enabling it to respond to inquiries effectively.
To obtain your API key, visit the OpenAI API key management page and click on “Create New Secret Key”. Once generated, copy this key and paste it into the designated field in Pabbly Chatbot.
- Ensure to save your API key securely.
- Test the connection by clicking the “Connect” button in Pabbly Chatbot.
This connection allows your AI assistant to access OpenAI’s features, providing intelligent and contextually relevant responses to customer inquiries.
4. Setting Up Your Knowledge Base for AI Assistant
The knowledge base is crucial for your AI assistant’s performance. Using Pabbly Connect, you can upload a PDF or text file containing all relevant information about your products and services.
To set this up, create a knowledge base file using Google Docs or any other text editor, ensuring it contains comprehensive details about your business. Supported formats include .txt and .pdf, with a maximum size of 90 MB.
- Upload the knowledge base file directly in Pabbly Chatbot.
- Ensure the file includes all necessary information to assist customers effectively.
With a well-structured knowledge base, your AI assistant will provide accurate and detailed responses, enhancing customer experience.
5. Finalizing Your AI Assistant Settings in Pabbly Chatbot
Finally, after setting up the knowledge base, you need to finalize the settings for your AI assistant using Pabbly Chatbot. Customize the interface, including the welcome message, and ensure the assistant is active.
Make sure to enable the option that allows the AI assistant to respond to chat inquiries. After configuring all settings, click the “Save Assistant” button to complete the setup.
Your AI assistant is now ready to interact with customers on WhatsApp, providing them with instant responses based on the knowledge base and OpenAI API integration.
In this tutorial, we demonstrated how to leverage Pabbly Connect to integrate Pabbly, Pabbly Chatbot, and OpenAI API for automated WhatsApp responses. This setup enhances customer engagement and streamlines communication effectively.
