1. Setting Up Pabbly Connect for Your Chatbot
To build a Real Estate WhatsApp Chatbot, the first step is to access Pabbly Connect. This platform enables seamless integration between various applications without the need for coding. Simply visit the Pabbly website and create your free account. Once registered, you will receive 100 free credits each month to explore and test the software.
After logging into your Pabbly Connect account, navigate to the flow builder. Here, you will set up the chatbot’s flow by defining triggers and actions. The user-friendly interface allows you to design your chatbot effectively by selecting options from the left-hand side menu.
2. Creating the Chatbot Flow in Pabbly Connect
Once inside the flow builder of Pabbly Connect, begin by naming your flow. Next, select the trigger event that will activate your chatbot. For this tutorial, choose the “Keywords” trigger. This means the chatbot will respond whenever a specific keyword is sent to your WhatsApp account.
  • Select the “Keywords” trigger event.
  • Enter the keywords you want to trigger the chatbot.
  • Add a welcome message that the chatbot will send in response.
After setting up the trigger, create a welcome message that introduces your real estate agency. This message will be sent automatically whenever a customer uses the specified keywords. You can customize this message to reflect your agency’s branding.
3. Adding Quick Buttons and Options
In this step, you will enhance your chatbot by adding quick buttons for user interaction. Using Pabbly Connect, you can easily add buttons like “Buy Property”, “Instant Support”, and “Our Portfolio”. These buttons will guide users to specific actions based on their needs.
To add buttons, simply click on the “Add Button” option and enter the button names. For example, create a button for “Buy Property” that leads to a list of property types. You can also set up buttons for instant support, which will connect users to an AI assistant.
  • Create a button for “Buy Property” and link it to the property list.
  • Add an “Instant Support” button to connect users to the AI assistant.
  • Include a button for “Our Portfolio” that sends users a PDF document.
These buttons not only enhance user experience but also streamline the conversation flow, allowing customers to easily navigate through their inquiries.
4. Collecting User Information through Pabbly Connect
To effectively manage leads, your chatbot must collect essential user information. With Pabbly Connect, you can set up fields to gather details such as the user’s name, contact number, preferred city, and budget. This data is crucial for personalizing the chatbot’s responses and managing leads efficiently.
For each piece of information, create a corresponding contact custom field in Pabbly Connect. For instance, when a user selects a property type, prompt them to provide their preferred city and budget. This interaction can be achieved by adding “Ask Question” nodes in the flow.
  • Set up custom fields for user data collection.
  • Use “Ask Question” nodes to prompt users for their preferences.
  • Link responses to the corresponding custom fields for better data management.
This setup ensures that all user interactions are recorded and can be used to generate leads automatically in Google Sheets through Pabbly Connect.
5. Integrating Google Sheets with Pabbly Connect
Finally, to automate lead management, integrate Google Sheets with your chatbot using Pabbly Connect. This process allows you to store all collected user information in a structured format, eliminating manual entry and ensuring data accuracy.
To set up this integration, create an API request in your Pabbly Connect workflow. Select Google Sheets as the action application and configure it to add new rows based on the data collected from your chatbot. This way, every time a user confirms their details, the information is automatically sent to your Google Sheets.
  • Create an API request to connect your chatbot with Google Sheets.
  • Map the fields from your chatbot to the corresponding columns in Google Sheets.
  • Test the integration to ensure data is being captured correctly.
This integration simplifies lead management, allowing real estate agencies to focus more on engaging with potential clients rather than handling data entry tasks.
In this tutorial, we demonstrated how to build a Real Estate WhatsApp Chatbot using Pabbly Connect without any coding skills. By following these steps, you can create an efficient lead management system that integrates seamlessly with Google Sheets.
Utilizing Pabbly Connect ensures that your chatbot operates smoothly, providing instant responses and collecting valuable user data effortlessly.
