1. Accessing Pabbly Connect to Build Your Real Estate Website
To create a real estate website, you need to access Pabbly Connect first. Go to pably.com and click on “Login” to access your Pabbly account. Here, you will find all Pabbly applications, including Pabbly Studio.
After logging in, locate Pabbly Studio and click on “Access Now.” This will take you to the Studio dashboard, where you can start building your website without any coding. Simply describe what you want, and the AI will handle the rest.
2. Building Your Website with Pabbly Studio
Once you are in the Studio dashboard, you can begin creating your website. Using Pabbly Connect, the AI will generate all necessary pages and features for your real estate site. Enter your requirements in simple words, and the AI will create a structured layout for you.
  • A clean design with large images
  • Property listings with filters
  • Agent profiles and a booking form
After entering your requirements, click “Submit” and watch as Pabbly Connect builds your application. This process typically takes a few minutes, depending on the complexity of your request.
3. Exploring the Features of Your Real Estate Website
Your newly created website will come with several features thanks to Pabbly Connect. The AI will generate essential pages like property listings, agent profiles, and a booking form for viewings. Each property will have its dedicated page with images and descriptions.
Additionally, the website will include a backend for managing inquiries. Here, you can see all booking requests, and each request can be marked as “Contacted” with a single click. This functionality is crucial for maintaining good client relations.
4. Updating Your Website with New Features
With Pabbly Connect, you can continually enhance your website. If you want to add a mortgage calculator, simply send another request through the Studio. The AI will quickly integrate this feature into each property page, allowing users to calculate monthly payments based on their inputs.
  • Enter the down payment amount
  • Specify the interest rate
  • Choose the loan term
The AI will ensure that the updated version goes live instantly. This flexibility allows you to adapt your website as your business needs evolve.
5. Integrating AI Tools with Pabbly Connect
Another significant advantage of using Pabbly Connect is its ability to integrate with AI tools like Claude and ChatGPT. You can connect these tools directly from the Studio, enabling advanced functionalities without consuming your AI credits.
To set this up, simply input the connection address into your AI tool. Once connected, you can build and update applications directly within the chat interface. This feature streamlines the development process and makes it more efficient.
With Pabbly Connect, you can manage your real estate website effortlessly, ensuring it meets your needs without any technical hurdles.
In conclusion, using Pabbly Connect allows you to create a fully functional real estate website with ease. By integrating various AI tools and features, you can enhance your site without coding, making it accessible for everyone.
