To start integrating Studio, One, and other applications, first access Pabbly Connect. Open your web browser and navigate to Pabbly.com. Click on the “Sign In” button to log in to your account.
Once logged in, you will see the Pabbly dashboard, which provides access to all Pabbly applications. Locate and click on “Pabbly Connect” to begin the integration process. This platform is crucial as it allows seamless connections between various applications without the need for coding.
2. Using Pabi Studio to Create Your Application
Now that you are in Pabbly Connect, you can use Pabi Studio to create your application. Click on “Access” next to Pabi Studio. This opens the Studio dashboard where you can design your app without writing any code.
  • Describe the application you want, such as a property management tool.
  • Specify the features needed, like dashboards, invoices, and tenant management.
  • Press “Send” to initiate the app creation process.
Pabi Studio will then generate the application based on your description. This process is facilitated by Pabbly Connect, ensuring that the necessary components are built efficiently.
3. Building Your App with Pabbly Connect
After sending your app description, Pabbly Connect will begin building your application. The AI in Pabi Studio manages the entire process, creating a dashboard, properties page, and invoice functionality.
During this phase, you can monitor the progress through a checklist. The build typically takes 2 to 5 minutes, depending on the complexity of your application. Once completed, the app will be live and accessible via a unique link.
Here are the key features that Pabbly Connect facilitates during this process:
  • Automatic deployment of your app.
  • Integration of a database for managing invoices and tenant information.
  • Responsive design for both desktop and mobile views.
4. Managing Invoices and Tenant Information
Once your app is built using Pabbly Connect, you can manage tenant information and invoices easily. For example, select a tenant, input their rent details, and generate an invoice.
After creating the invoice, you can mark it as paid by selecting the payment method and recording the transaction. This functionality is essential for landlords to keep track of their finances efficiently.
Moreover, Pabbly Connect ensures that all invoice data is stored in a database, allowing you to access and manage it from the data tab. This feature enhances your ability to oversee multiple properties and tenants seamlessly.
5. Updating and Rolling Back Changes in Your App
With Pabbly Connect, updating your app is straightforward. If you wish to add new features, such as a maintenance page, simply send a request through Pabi Studio. The system will make the necessary changes and publish a new version.
If you decide you prefer a previous version, Pabbly Connect allows you to roll back changes easily. Each version is saved with a description, enabling you to revert to an earlier state without losing data.
This version control is crucial for maintaining the integrity of your application while allowing flexibility in updates. You can manage changes effectively, ensuring your app always meets your needs.
In this tutorial, we explored how to use Pabbly Connect to integrate Studio, One, and various applications effortlessly. With features like automatic deployment, version control, and easy management of tenant information, Pabbly Connect simplifies the process of building and maintaining your applications.
