Accessing Pabbly Connect for WhatsApp Integration
To start integrating WhatsApp with Pabbly Connect, first, navigate to the Pabbly website. You need to create an account if you are a new user. Once logged in, you will be directed to the Pabbly Connect dashboard.
From the dashboard, you can easily manage your integrations. Click on the “Create Workflow” button to begin setting up your WhatsApp automation. This process will utilize Pabbly Connect to streamline your communications.
Setting Up WhatsApp Integration with Pabbly Connect
Once you are in the Pabbly Connect dashboard, the next step is to add your WhatsApp Business number. Click on the “Add WhatsApp Number” button to connect your account. This connection is crucial as it allows Pabbly Connect to send and receive messages on your behalf.
  • Click on “Add WhatsApp Number”.
  • Enter your WhatsApp Business number.
  • Verify your number to complete the setup.
After successfully adding your number, you will be able to automate responses using Pabbly Connect. This integration allows you to handle customer queries effectively without manual intervention.
Creating an AI Agent Using Pabbly Chatflow
Now that your WhatsApp number is connected, the next step is to create an AI agent using Pabbly Chatflow. Click on “Add Assistant” to start this process. You will need to give your assistant a name, such as “E-commerce AI”.
Once the assistant is created, you will choose the type of instructions for your AI. Select the “Customer Support” option to ensure your agent can handle queries effectively. This is where Pabbly Connect comes into play, enabling your AI to respond to customer inquiries automatically.
  • Choose “Customer Support” as the instruction type.
  • Set the temperature for responses to balance creativity and focus.
  • Integrate the OpenAI API key for advanced responses.
After configuring these settings, your AI agent will be ready to assist customers through WhatsApp, showcasing the power of Pabbly Connect in automating business communications.
Uploading Knowledge Source for Your AI Agent
To enhance your AI agent’s capabilities, you need to upload a knowledge source. This can be a PDF or text file containing information about your products, policies, and services. Click on “Upload File” and select your knowledge source to provide the necessary context for your AI.
Once uploaded, your AI agent can utilize this information to answer customer queries accurately. This feature is a significant advantage of using Pabbly Connect, as it allows for a more personalized customer experience based on the provided data.
Assigning Your AI Assistant in Pabbly Connect
Finally, you can assign your AI assistant to specific chats or enable it to respond to all incoming messages. To do this, navigate to the “Inbox Settings” and enable the “AI Auto Reply” feature. This allows Pabbly Connect to automatically handle customer inquiries based on the settings you have configured.
To assign your assistant, choose the contacts you want to enable this feature for. Once set up, your AI assistant will handle all queries seamlessly, ensuring that no customer goes unanswered.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect and create an AI assistant using Pabbly Chatflow. This powerful setup allows businesses to automate responses and improve customer service efficiently.
