1. Introduction to Pabbly Connect for Finance Support
Pabbly Connect is a powerful integration platform that allows you to automate workflows between various applications. In this tutorial, we will build a no-code AI finance support system using Pabbly Connect to streamline finance-related queries through WhatsApp. This setup will help your finance team focus on more critical tasks instead of repetitive questions.
Using Pabbly Connect, we will integrate WhatsApp with a knowledge base in Google Docs to create an AI assistant. This assistant will handle inquiries about reimbursement policies, invoice statuses, and more. By following the steps outlined in this tutorial, you can create a similar system for your business.
2. Setting Up Pabbly Connect for WhatsApp Integration
To get started with Pabbly Connect, first, navigate to the Pabbly website and sign up for a free account. Once you’re logged in, go to the Pabbly Connect dashboard. From here, you can create a new workflow that connects WhatsApp with your finance assistant.
- Log in to your Pabbly account.
- Go to the dashboard and click on ‘Create New Workflow.’
- Select WhatsApp as your trigger application.
After setting up the trigger, you will need to configure the action step, which will be linked to your AI assistant. This is where Pabbly Connect shines, allowing seamless communication between WhatsApp and your assistant.
3. Creating the AI Assistant with Pabbly Connect
Once you have set up the initial workflow in Pabbly Connect, the next step is to create your AI assistant. Navigate to the Pabbly Chatflow dashboard, where you can start building your assistant. Click on the ‘Add Assistant’ button and give your assistant a meaningful name.
In this section, you will define the AI instructions. Select the AI agent type and configure its settings. For example, you can set the temperature to 0.5 for balanced creativity. Make sure to add your OpenAI API key to connect Pabbly Connect with your AI assistant.
- Define the AI role and constraints.
- Set the temperature for AI responses.
- Add your OpenAI API key.
With these configurations in place, your AI assistant will be ready to handle finance-related queries via WhatsApp, making use of the information stored in your Google Docs.
4. Integrating Knowledge Sources for AI Responses
The next step in setting up your AI finance assistant is to integrate a knowledge source. This is crucial for providing accurate responses to user queries. In Pabbly Connect, you can easily upload a file containing FAQs and other relevant information that your assistant can utilize.
To do this, click on the ‘Add Knowledge Source’ button in the Pabbly Chatflow dashboard. Upload your pre-prepared file in either PDF or TXT format. Once uploaded, the AI assistant will be able to access this information to respond to finance-related questions.
- Click on ‘Add Knowledge Source.’
- Upload your file with FAQs and company details.
- Ensure the file is in PDF or TXT format.
After successful integration, your AI assistant will be equipped to provide accurate answers based on the knowledge base you have created.
5. Testing and Launching Your AI Assistant
Once your AI assistant has been configured and integrated with the knowledge source, it’s time to test its functionality. In the Pabbly Connect dashboard, create a flow that triggers the assistant when specific keywords are sent via WhatsApp.
For example, set the trigger keyword as “finance.” Whenever this keyword is received, the assistant should respond with a welcome message and offer options for assistance. Connect the assistant node to ensure it activates upon receiving the keyword.
- Create a flow in Pabbly Connect.
- Set the trigger keyword as “finance.”
- Connect the assistant node to the flow.
After saving your flow, test it by sending the keyword “finance” via WhatsApp. Your assistant should respond instantly, confirming that the integration is successful and operational.
In this tutorial, we demonstrated how to build a no-code AI finance support system using Pabbly Connect. By integrating WhatsApp with your AI assistant, you can automate responses to finance-related queries efficiently. This setup not only saves time but also improves overall productivity within your finance team.
