1. Accessing Pabbly Connect for Your Chatbot
To build a hotel booking chatbot that handles reservations automatically, you need to access Pabbly Connect. Start by visiting pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage, where you can log in or sign up for a free account.
If you are a new user, click on “Sign Up Free” to create your account. If you already have an account, simply log in. Once logged in, you can access various Pabbly applications, including Pabbly Chat Flow, which is essential for chatbot creation.
2. Setting Up Pabbly Chat Flow for the Chatbot
After logging into Pabbly Connect, navigate to the Pabbly Chatbot Flow section by clicking on “Access Now”. This will direct you to the Pabbly Chatbot Flow dashboard. Here, you can see all your existing chatbot flows and create new ones.
To create a new flow, click on the “Add Flow” button. You will be prompted to set up a trigger for your chatbot. For this hotel booking chatbot, you can use a keyword trigger. Here’s how to do it:
- Select “Keyword” as your trigger type.
- Enter a keyword (like “Hello”) and press Enter.
- Save your trigger settings.
After setting your trigger, you can start designing the chatbot flow.
3. Designing the Chatbot Flow with Pabbly Connect
In this step, you will design the flow of your hotel booking chatbot using Pabbly Connect. You can add various elements such as media buttons and text responses. Begin by dragging and dropping the media button element into your flow.
Next, upload an image of your hotel and add a welcoming message that includes options like “Rooms and Prices”. For example:
- Add a media button with your hotel image.
- Include a text message with options for the user.
- Link the button to a list of room categories.
This setup allows users to select their preferred room type easily, enhancing user interaction.
4. Collecting User Information through the Chatbot
Once users select their room category, your Pabbly Chat Flow will need to collect their information for booking. You can do this by adding a question node that prompts the user for their name, check-in date, and check-out date.
To implement this:
- Drag a question node into your flow.
- Ask for the user’s name and store it in a custom field.
- Repeat for check-in and check-out dates.
This process ensures that you gather all necessary information for the reservation automatically, streamlining the booking process.
5. Finalizing Your Hotel Booking Chatbot
To finalize your chatbot setup, ensure that all elements are correctly linked and functioning within Pabbly Connect. Review the flow to confirm that it captures all user inputs and sends a confirmation message at the end of the interaction.
Once satisfied, name your flow and activate it. Don’t forget to save your changes. This will make your hotel booking chatbot live and ready to handle reservations automatically. Following these steps ensures a smooth and efficient booking process for your customers.
In conclusion, by utilizing Pabbly Connect and its various applications, you can create an efficient hotel booking chatbot that handles reservations automatically. This setup not only enhances customer experience but also automates the booking process, freeing up your time for other business activities.
