To create a WhatsApp Business assistant powered by GPT, you first need to access Pabbly Connect. Go to pabbly.com/chatflow in your browser. This will take you to the Pabbly Chat Flow homepage where you can explore various options.
If you’re a new user, click on “Sign Up Free” to start using Pabbly Connect. Existing users can simply log in. This platform is essential for integrating your WhatsApp Business with GPT functionalities.
2. Setting Up Pabbly Chat Flow
Once logged into Pabbly Connect, navigate to the Pabbly Chat Flow dashboard. Here, you will see the option to link your WhatsApp number. If you need assistance, tutorial videos are available on the Pabbly website.
- Click on “Access Now” for Pabbly Chat Flow.
- Link your WhatsApp number in the settings.
- Explore the dashboard to familiarize yourself with the interface.
In this section, you will set up your assistant using the “AI Assistant” feature in Pabbly Connect. This is crucial for automating responses to customer inquiries on WhatsApp.
3. Creating Your AI Assistant
To create your AI assistant, click on the “Add” button under the AI Assistant section in Pabbly Connect. Give your assistant a name and click the add button to proceed. This will lead you to a flow window where you can set up your assistant’s capabilities.
Here, select the type of instructions from the dropdown menu. You can either add your own prompts or use predefined examples. Once you’ve selected the type, basic instructions will appear, allowing you to customize further.
- Choose the AI instruction type from the dropdown.
- Adjust the creativity level for responses.
- Select OpenAI as your AI provider.
In this step, you will also configure the API key for OpenAI, which is necessary for your assistant to function properly. This is where Pabbly Connect plays a vital role in linking your assistant with GPT technology.
4. Configuring Assistant Settings
After setting up the AI assistant, you need to configure various settings. Start with the header message, which can be activated by toggling the button. You have a character limit for this message, so ensure it’s concise.
Next, you will set keywords for stopping responses. For example, if a customer types “human”, the assistant will cease responding, allowing a human to take over. This feature is crucial for maintaining customer service quality.
- Add keywords that will stop the assistant’s responses.
- Set retry attempts before sending a fallback message.
- Upload knowledge sources in supported formats.
These configurations ensure that your assistant is responsive and effective, integrating seamlessly through Pabbly Connect with your WhatsApp Business account.
5. Activating Your Assistant for WhatsApp
Once you have configured all settings, it’s time to activate your assistant. Enable the assistant by toggling the activation button and click “Save” to finalize your setup. This step is crucial for your assistant to start responding to inquiries on WhatsApp.
You can also set your assistant for specific WhatsApp chats or for all contacts collectively. This flexibility allows you to tailor the assistant’s functionality to meet your business needs.
- Toggle the activation button to enable your assistant.
- Choose to set the assistant for all contacts or specific chats.
- Click “Save” to apply all changes.
With these final steps, your AI assistant is now live and operational, powered by Pabbly Connect. This integration allows for efficient communication and customer service through WhatsApp Business.
Creating a WhatsApp Business assistant powered by GPT using Pabbly Connect is a straightforward process. By following these steps, you can automate responses and enhance customer engagement effectively.
