To start integrating various applications like Pabbly Chatbot and OpenAI, you need to access Pabbly Connect. Open a new tab and visit pabbly.com/chatfuel to create your account.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you can see all your applications. Select Pabbly Chatbot from the options available. This is where you will build your AI assistant.
2. Creating Your AI Assistant Using Pabbly Connect
After accessing Pabbly Chatbot, you can create an AI assistant by clicking on the “Add AI Assistant” button. Give your assistant a name and description. This is crucial for identifying your assistant later.
- Click on the “Add AI Assistant” button.
- Enter a suitable name and description for your assistant.
- Select the type of instructions as “AI agent”.
Once you have entered these details, click on the “Add AI Assistant” button again. Your AI assistant is now created, and you can begin configuring its responses and settings through Pabbly Connect.
Now that your AI assistant is created, it’s time to configure its settings. In this section, you can set the temperature for responses, which influences the creativity of the AI. A lower temperature yields more stable responses, while a higher one allows for more creative outputs.
Select OpenAI as your model provider and choose the GPT-4 o-mini model. You will also need to enter your OpenAI API key, which you can generate from the OpenAI API keys page.
- Set the temperature level (e.g., 0.5 for balanced responses).
- Paste your OpenAI API key in the designated field.
- Click on the “Connect” button to save your settings.
After connecting, you will see a message confirming that your OpenAI key is saved successfully. This integration is facilitated by Pabbly Connect, ensuring smooth communication between your applications.
4. Training Your AI Assistant with Knowledge Base
To enhance the AI assistant’s responses, you must upload a knowledge base file. This file contains all relevant information about your business, which the AI will use to provide accurate answers.
Ensure your file is in .pdf or .txt format and less than 90 MB in size. You can create this file using Google Docs or any text editor. Once ready, click on the “Add New File” option to upload your knowledge base.
- Prepare a knowledge base containing your business details.
- Click on “Add New File” and select your file.
- Insert the file by clicking the “Insert” button.
With the knowledge base uploaded, your AI assistant can now provide tailored responses based on your business information, thanks to the capabilities of Pabbly Connect.
5. Finalizing Your AI Assistant in Pabbly Connect
After training your AI assistant, you need to finalize its design and settings. Customize the title and subtitle to reflect your brand. You can also edit the welcome message that users will see when they interact with your assistant.
Make sure to activate your assistant by toggling the activation switch and clicking on the “Save Assistant” button. This ensures that your assistant is live and ready to assist customers.
- Customize the title and subtitle for your assistant.
- Edit the welcome message to engage users.
- Toggle the activation switch and save your assistant.
By completing these steps, your AI assistant is ready to operate through WhatsApp, providing seamless customer interaction powered by Pabbly Connect.
In this tutorial, we explored how to integrate Pabbly Chatbot, OpenAI, and other applications using Pabbly Connect. By following these steps, you can create a powerful AI assistant for your business.
