To start integrating Facebook leads with Pabbly Connect, first visit the Pabbly Connect website. Pabbly Connect is your go-to platform for automating workflows seamlessly. If you are new, click on the ‘Sign Up Free’ button to create your account.
After signing up, you will receive 100 free tasks every month, allowing you to explore Pabbly Connect’s features. If you already have an account, simply log in and navigate to the dashboard to begin creating your workflow.
2. Creating Your Facebook Lead Workflow with Pabbly Connect
Once you’re in the Pabbly Connect dashboard, click on the ‘Create Workflow’ button. This is where you’ll set up your Facebook lead management system. Choose to create a workflow from scratch and give it a meaningful name.
  • Select the folder where you want to store this workflow.
  • Click the ‘Create’ button to proceed to the workflow setup page.
Now, select Facebook Lead Ads as your trigger application. This ensures that your workflow is activated whenever a new lead is captured through your Facebook ads.
After selecting Facebook Lead Ads, you need to create a connection between Facebook and Pabbly Connect. Click on the ‘Add New Connection’ option and follow the prompts to authorize Pabbly Connect to access your Facebook account.
Once connected, choose the Facebook page linked to your lead ads. Then, select the specific form you want to use for capturing leads. Ensure that the response format is set to simple for better compatibility.
4. Testing Your Facebook Lead Integration with Pabbly Connect
To test your integration, you need to submit a test lead through your Facebook form. After submitting, Pabbly Connect will wait for a webhook response to capture the lead details.
Once the lead is captured successfully, you will see the details reflected in your Pabbly Connect dashboard. This confirms that your Facebook Lead Ads are now integrated and functioning correctly.
5. Storing Leads in Airtable via Pabbly Connect
Now that your leads are being captured, the next step is to store them in Airtable. Select Airtable as your action application in Pabbly Connect. Choose the ‘Create Record’ action event to add new leads into your Airtable base.
  • Connect your Airtable account by following the prompts.
  • Select the base and table where you want to store your leads.
Finally, map the fields from your Facebook lead form to the corresponding fields in Airtable. This ensures that all lead information is accurately stored. Once everything is set up, click ‘Save and Send Test Request’ to verify that the integration is working.
In this tutorial, we explored how to use Pabbly Connect to automate your Facebook lead management. By integrating Facebook Lead Ads with Airtable, you can streamline your workflow and ensure no lead goes unmanaged. Start using Pabbly Connect today to enhance your lead management process.
