1. Accessing Pabbly Connect for Drip Campaigns
To start using Pabbly Connect for your educational institute, first, you need to access the platform. Simply visit the Pabbly website and navigate to the Pabbly Connect section. This integration platform allows you to connect various applications seamlessly.
Once on the Pabbly Connect dashboard, you can begin setting up your workflow for drip campaigns. This is crucial for sending timely WhatsApp messages to your leads, ensuring they remain engaged with your institute.
2. Setting Up WhatsApp Integration with Pabbly Connect
In this section, you will learn how to integrate WhatsApp using Pabbly Connect to send messages as part of your drip campaign. First, ensure that you have added your WhatsApp number in Pabbly Connect.
  • Log into your Pabbly Connect account.
  • Navigate to the flows section.
  • Click on the “Add Flow” button to start a new workflow.
Once you have set up your WhatsApp number, you can begin creating your drip campaign by naming your flow and selecting the appropriate trigger event. This is where Pabbly Connect shines, allowing you to automate your messaging process.
3. Creating a Drip Campaign Flow in Pabbly Connect
To create an effective drip campaign, you will need to set up a series of messages that will be sent to your leads over time. Start by naming your flow, for example, “Student Admission Drip Campaign.” This step is essential for organizing your campaigns within Pabbly Connect.
Next, select the trigger event as “WhatsApp template delivered.” Here, you will choose the WhatsApp template that you previously created and got approved by Meta. This ensures that once the initial message is sent, the subsequent messages will follow as planned.
  • Drag and drop the delay action node to set a delay for your next message.
  • Select the delay type according to your campaign needs.
  • Input the message content for the next follow-up.
With Pabbly Connect, you can easily customize the timing and content of your messages, making your drip campaign highly effective and personalized.
4. Finalizing Your Drip Campaign in Pabbly Connect
After setting up the messages and delays, it’s time to finalize your drip campaign. You can clone existing delay steps and message boxes to maintain consistency in your campaign.
For each follow-up message, specify the delay period and customize the content accordingly. Pabbly Connect allows you to use dynamic fields like “dollar name” to personalize each message, enhancing engagement with your leads.
Don’t forget to click on the “Save” button to save your flow. This is a critical step to ensure that your drip campaign functions as intended, sending messages at the designated times.
5. Conclusion
In conclusion, using Pabbly Connect to set up a drip campaign for your educational institute is a straightforward process. By following the steps outlined, you can effectively engage your leads through timely WhatsApp messages.
Pabbly Connect simplifies the integration process, allowing you to manage your campaigns efficiently. Start your free trial today and see the benefits of automated messaging for your institute!
