1. Accessing Pabbly Connect for Your Dashboard
To start building your Business KPI Dashboard, access Pabbly Connect by navigating to pably.com and logging into your account. Once logged in, you will find all Pabbly applications, including Pabbly Studio, in one place.
After logging in, click on the “Access Now” button for Pabbly Studio. This is where you will create your dashboard without any coding. The interface is user-friendly and designed for no-code solutions.
2. Creating the Dashboard with Pabbly Studio
Once you are in Pabbly Studio, you can start describing the application you want to create. For this dashboard, you will include key metrics like revenue, orders, and new customers.
  • Specify the dashboard layout and metrics.
  • Include charts for performance tracking against goals.
  • Designate sections for sales by channel and region.
After entering your specifications, click the “Submit” button. Pabbly Connect will initiate the AI process to build your dashboard, which typically takes 2 to 5 minutes.
3. Reviewing Your KPI Dashboard
Once the building process is complete, you can review the application created by Pabbly Connect. It includes a login page, key metrics, and various charts to visualize performance.
Your dashboard will show metrics like revenue, orders, average order value, and new customers, all compared to the previous month. You can also see a chart displaying revenue against your goal, sales by channel, and top products.
4. Updating Your Dashboard with Pabbly Connect
To ensure your dashboard remains accurate, you can update the figures directly on the data page. For example, if you need to adjust current revenue or orders, simply input the new values and save the changes.
  • Update revenue and order figures.
  • Adjust monthly revenue goals as needed.
After making these adjustments, the dashboard will instantly reflect the new totals and updated charts. This real-time data management is one of the key benefits of using Pabbly Connect.
5. Integrating AI Tools with Pabbly Connect
If you want to enhance your dashboard further, you can integrate AI tools like Claude or ChatGPT through Pabbly Connect. This allows you to manage your applications and update them with simple commands.
To integrate these AI tools, add the specified address to your AI tool settings. This will enable you to create and modify applications using natural language without consuming your AI credits.
With Pabbly Connect, you can build a front-end and back-end system with a ready-to-use database, automatic hosting, and a live link to your dashboard, all without writing a single line of code.
Building a Business KPI Dashboard with Pabbly Connect allows for seamless integration of various applications like Studio and ChatGPT. This no-code approach simplifies data management and enhances business insight.
