1. Accessing Pabbly Connect for Your Expense Tracker
To build a Business Expense & Receipt Tracker, the first step is accessing Pabbly Connect. Begin by typing paby.com in your browser and clicking on the sign-in button. Once logged in, you will have access to all Pabbly applications.
After signing in, scroll down to find Pabbly Studio and click on access. This will take you to the no-code editor where you can easily describe your app requirements without any coding knowledge.
2. Building the App with Pabbly Studio
Once in Pabbly Studio, you will see a box where you can describe your app. For this project, you will create an expense tracker called Tally, where staff can submit expenses along with receipt photos.
The AI in Pabbly Connect will help you build the app step by step. It will create a plan that includes:
  • Staff submitting expenses
  • Manager approvals
  • Monthly spending totals
Now, simply send the prompt, and the AI will start building your app.
3. Navigating Staff and Manager Interfaces
With your app built, the next step is to explore the staff and manager interfaces. Staff members will log in to see their spending overview, which includes a big number showing their total spending for the month.
When staff add an expense, they will input the amount, purpose, and category while attaching a photo of the receipt. After submitting, the claim appears at the top of their list marked as pending. The manager side allows for easy approval or rejection of claims, which is facilitated by Pabbly Connect.
4. Tracking and Managing Claims with Pabbly Connect
Managing claims is seamless with Pabbly Connect. Managers can view all pending claims alongside their respective receipts. They can approve or reject claims with a single click, which updates the status in real-time without needing to refresh the page.
This feature ensures that every decision is instantly reflected in the staff’s overview. Each claim’s status is updated, and Pabbly Connect keeps a complete database of every claim under the data tab, making it easy to track and manage expenses efficiently.
5. Enhancing Your App with New Features
One of the best aspects of using Pabbly Connect is the ability to enhance your app easily. If you want to add a reimbursement feature, simply send a prompt to Pabbly Studio. The AI will update the app to include a new payouts page, showing each approved claim and its payment status.
Additionally, Pabbly Connect allows you to roll back to previous versions if you want to revert any changes. This version history ensures that you can manage your application effectively without losing any important data.
In summary, using Pabbly Connect and Pabbly Studio, you can easily build a Business Expense & Receipt Tracker. This integration allows for seamless management of expenses, approvals, and tracking, enhancing your team’s productivity.
