1. Accessing Pabbly Connect for Your Game
To start integrating Studio and Every, you first need to access Pabbly Connect. Simply visit Pabi.com and click on the “Sign In” button. This will take you to your Pabi account, where you can find all the Pabi applications.
Once logged in, locate Pabbly Connect and click on “Access Now”. This will direct you to the Pabbly Connect dashboard where you can initiate the integration process.
2. Creating Your Burger Ordering Game in Studio
After accessing Pabbly Connect, you’ll begin creating your burger ordering game using Pabi Studio. The first step is to describe your game concept in plain words. You can type your game description in the provided box.
  • Describe the game as an original burger cooking game called Bun Rush.
  • Mention that order tickets slide in, and players build burgers by clicking ingredients.
  • Specify that players earn coins for correct orders and have a leaderboard.
Once you describe your game, click “Send” to initiate the building process. Pabbly Connect will use your description to create the game automatically.
3. Building and Deploying the Game with Pabbly Connect
After sending your game description, Pabbly Connect will begin the building process. The AI will generate all necessary components for the game, including the game screen, controls, and leaderboard.
You will see a checklist that indicates the progress of the build. The entire process usually takes 2 to 5 minutes. Once completed, your game will go live on its own link without requiring any hosting or database setup.
During this process, Pabbly Connect manages everything from deployment to hosting, ensuring a seamless experience. You won’t need to worry about SSL certificates or server arrangements.
4. Exploring Game Features and Functionality
With the game live, you can now explore its features. The game includes components such as the scoring system, leaderboard, and order tracking. You can start the service and watch as orders slide in.
  • Players earn coins for correctly served burgers and gain extra time.
  • Incorrect orders will result in a time penalty.
  • The leaderboard displays all players’ scores, fostering competition.
Using Pabbly Connect, you can easily make modifications to the game. For instance, you can add new features or change existing ones by simply describing them in the prompt.
5. Updating and Managing Your Game with Pabbly Connect
As you continue to develop your game, Pabbly Connect allows you to make updates effortlessly. You can request changes, such as adding a “Burger of the Day” or modifying the game’s visual elements.
Each update generates a new version of the game, which is saved automatically, allowing you to roll back to previous versions if needed. This feature ensures that you can experiment without losing your previous work.
Ultimately, Pabbly Connect simplifies the management of your game, providing a user-friendly interface to track all changes and updates. You can also connect to AI tools like Claude or Chat GPT for further enhancements.
In this tutorial, we explored how to use Pabbly Connect to create a burger ordering game using Studio and Every. By following these detailed steps, you can easily build and manage your game while enjoying the benefits of seamless integration.
