1. Accessing Pabbly Connect for Your Blog Website
To build a blog website with an admin editor using AI, you first need to access Pabbly Connect. Start by visiting pably.com and logging into your account.
Once logged in, you will see a dashboard displaying all Pabbly applications. Select Pabbly Studio and click on “Access Now” to begin your project. This is where you will create your blog application without writing any code.
2. Creating Your Blog Application in Pabbly Studio
After accessing Pabbly Studio, you will see a blank space to describe your application. For this blog, you will create a detailed request outlining the specific features you want.
- The blog should feature a full-width image for the latest story.
- Users can filter posts by category and search while typing.
- Each post should read like a magazine page.
With these features defined, click “Submit” to allow Pabbly Connect to begin building your application. The AI will start working on your request immediately.
3. Building the Blog Website with Pabbly Connect
Once you submit your request, Pabbly Connect will take a few minutes to build your blog website. The AI will generate the layout, ensuring it resembles a printed magazine with a warm ivory background and bold serif headings.
The latest story will be displayed prominently at the top, with a progress bar indicating how much of the article has been read. Below this, users can find an archive categorized into four sections.
- The AI will automatically find and insert images for each story.
- Users can filter stories by category or search for specific terms.
- Each story opens like a magazine page with a large title and summary.
After the build is complete, you will receive a unique link to access your blog website. This link is generated by Pabbly Connect and requires no additional hosting setup.
4. Utilizing the Admin Editor with Pabbly Connect
In this section, we will explore how the admin editor works within your blog website. The author, Enis Varela, will log in using her email and password, accessing a personal dashboard.
This dashboard allows her to create, edit, and publish posts seamlessly. The interface is designed to show all published stories on one side and an option to create new stories on the other.
- Enis can enter a title, a one-line introduction, and select a category for each post.
- She can also upload a cover image and format the body text using hashtags for subheadings.
- Once completed, she clicks “Publish” to feature her story at the top of the homepage.
All of these actions are facilitated through Pabbly Connect, ensuring a smooth and efficient publishing process.
5. Modifying Your Blog Website with Pabbly Connect
After the initial setup, you may want to modify your blog website. This can be done easily through Pabbly Connect. For instance, Enis can add a new section for editor’s picks directly below the latest story.
By making a simple request in Pabbly Studio, the AI will adjust the layout to include three selected stories with images and categories highlighted.
Additionally, any changes made will be saved as different versions, allowing Enis to revert to previous layouts if necessary. This versioning feature is a powerful aspect of Pabbly Connect, ensuring flexibility in design.
Building a blog website with an admin editor using AI and no code is made easy with Pabbly Connect. This tutorial has outlined the steps to create, modify, and manage your blog effectively.
With Pabbly Connect, you can streamline your blogging process, ensuring a professional-looking site with minimal effort.
