To start integrating Pabbly Chatbot with OpenAI, first, access Pabbly Connect by visiting pabbly.com/chatbot in your browser. This will direct you to the Pabbly Chatbot homepage where you can either log in or sign up for a free account. If you’re a new user, click on the “Sign Up Free” button to create your account.
Once logged in, navigate to the “All Pabbly Applications” section. Here, locate and select Pabbly Chatbot by clicking on the “Access Now” button. This will take you to the Pabbly Chatbot dashboard, where you can start setting up your AI assistant.
2. Setting Up Your AI Assistant with Pabbly Connect
To create an AI assistant, you can use Pabbly Connect to streamline the process. From the left sidebar, select the option to create a new assistant. Give your assistant a name and click the “Add” button. This action will open a flow window where you can customize your assistant’s settings.
- Choose the instruction type from the dropdown menu.
- Select either “Custom Instruction” or predefined examples.
- Set the AI model to OpenAI and select the appropriate version.
After setting the instruction type, you can adjust the AI settings. One key setting is the “Temperature,” which determines the creativity of the AI’s responses. A lower value, like 0.4, yields more focused answers, while higher values produce more creative responses.
3. Configuring OpenAI API in Pabbly Connect
Integrating OpenAI into your assistant requires using Pabbly Connect. You will need your OpenAI API key. In the settings, find the field labeled “API Key” and enter your OpenAI key. If you don’t have one, you can generate it from your OpenAI account by clicking the provided link in the interface.
Additionally, set up the assistant’s message settings. You can add a title message and a fallback message. The fallback message will be sent if the API fails to respond correctly. Ensure you customize these messages to fit your business needs.
- Enable the option for the assistant to respond to specific keywords.
- Set retry attempts for the AI’s responses.
- Upload a knowledge source file for accurate responses.
Completing these steps ensures your assistant is ready to interact effectively using the OpenAI API through Pabbly Connect.
4. Finalizing Your AI Assistant in Pabbly Connect
After configuring your assistant, the next step is to finalize it using Pabbly Connect. You can activate the assistant by enabling the switch at the top of the settings page. Don’t forget to click the “Save” button to ensure all your configurations are stored correctly.
Moreover, you can customize the appearance of your assistant. Choose between light or dark themes and adjust the shape of the chat window. You can also upload a profile picture and background image to enhance your assistant’s visual appeal.
Finally, you can embed your assistant on your website using the provided integration options. This allows your customers to interact with your AI assistant directly from your site, providing a seamless experience.
5. Assigning Your Assistant to WhatsApp Using Pabbly Connect
The last step in this integration process involves assigning your AI assistant to your WhatsApp account using Pabbly Connect. Navigate to the “Incoming Mail Settings” section and locate the option for automatic AI responses. Enable this feature and select your assistant from the dropdown menu.
For individual conversations, you can assign the assistant by selecting a specific chat and choosing the assistant from the available options. This feature allows for both group and individual chat assignments, ensuring your assistant can handle multiple interactions efficiently.
- Enable AI responses for all contacts or specific ones.
- Select the assistant you want to assign for each chat.
By completing these steps, your AI assistant is now fully integrated with WhatsApp, ready to assist your customers effectively using Pabbly Connect.
In this tutorial, we explored how to integrate Pabbly Chatbot and OpenAI using Pabbly Connect. By following these steps, you can create a powerful AI assistant for your business. This integration enhances customer interactions and streamlines communication.
