To start integrating your WhatsApp AI assistant, access Pabbly Connect. This platform simplifies the process of connecting various applications seamlessly.
Once you log in, navigate to the dashboard where you can create a new workflow. Ensure that you have your WhatsApp number ready for integration.
2. Creating Your AI Assistant with Pabbly Chatflow
Creating an AI assistant is straightforward using Pabbly Connect. Visit the Pabbly Chatflow page by entering the URL in your browser. You can sign up for free and explore the features.
- Sign up for a free account to receive 100 free credits monthly.
- Log in if you already have an account.
After logging in, ensure to link your WhatsApp number to the Pabbly Chatflow account. This allows the AI assistant to respond to customer inquiries effectively.
3. Configuring AI Assistant Settings in Pabbly Connect
In this step, you will configure your AI assistant settings using Pabbly Connect. Select the instruction type and set the temperature for the AI, which determines its creativity level.
For optimal performance, set the temperature to 0.5. Next, you need to enter your OpenAI API key. This key is essential for the AI to respond to customer queries.
- Visit the OpenAI API key page to create a new secret key.
- Save the API key in your Pabbly Connect settings.
Once configured, your AI assistant will be equipped to handle customer inquiries 24/7.
4. Enabling Auto Replies for Your AI Assistant
To enable auto-replies, navigate to the settings in Pabbly Connect. This feature allows your AI assistant to respond automatically to incoming messages.
Scroll down to the inbox settings and enable the auto-replies option. Here, you can choose to enable it for all contacts or specific ones.
- Select the AI assistant you created for your contacts.
- Ensure the assistant is activated for the selected contacts.
With auto-replies enabled, your AI assistant will handle customer inquiries without manual intervention.
5. Embedding Your AI Assistant on a Website
To embed your AI assistant on your website, use Pabbly Connect. After saving your assistant, click on the embed button to get the script code.
Copy this code and paste it into your website’s HTML. This allows your AI assistant to interact with visitors directly from your site.
- Ensure to test the assistant after embedding.
- Customize the appearance if needed.
Embedding the assistant enhances customer engagement, allowing for seamless communication through WhatsApp.
Using Pabbly Connect, you can effortlessly create and integrate a WhatsApp AI assistant to automate customer inquiries. This setup not only saves time but also enhances customer satisfaction by providing instant responses.
