To begin using Pabbly Chatflow, open your web browser and navigate to pabby.com/chatflow. This is the starting point for integrating WhatsApp with your business communications.
If you are a new user, click on the “Sign Up for Free” button to create an account. Existing users can simply log in. Once logged in, you will see the Pabbly apps window. Click on “Access Now” under Pabbly Chatflow to reach the dashboard.
2. Setting Up WhatsApp Broadcast in Pabbly Chatflow
To send bulk WhatsApp messages, you need to set up a broadcast using Pabbly Chatflow. On the dashboard, locate the “Broadcast” feature on the left sidebar. Click on it to view your existing broadcasts.
- Click the “Add Broadcast” button to initiate a new broadcast.
- Choose “Broadcast Campaign” as the type.
- Name your broadcast, for example, “New Sale Offers”.
After naming your broadcast, select the contact list to whom you want to send the message. If you have contacts stored in Google Sheets, ensure they are uploaded as a CSV file to Pabbly Chatflow.
3. Uploading Contacts to Pabbly Chatflow
To send messages via WhatsApp, you must first upload your contacts into Pabbly Chatflow. Click on the “Contacts” section in the left sidebar. Here, you can view existing contacts or add new ones.
- To add a single contact, click “Add Contact” and fill in the details.
- For bulk upload, select “Add Bulk Contacts” and upload your CSV file.
Once the contacts are uploaded, create a contact list that can be used for your broadcast. Select this list when setting up your WhatsApp broadcast.
4. Crafting Your WhatsApp Message in Pabbly Chatflow
Now that your contacts are uploaded, you can craft your WhatsApp message. In Pabbly Chatflow, under the broadcast settings, you will select the message type. Choose between a pre-approved template or a regular message.
For this tutorial, select a pre-approved template. If you don’t have one yet, create a new template in the Templates section. Ensure your template includes variables for personalization, like the recipient’s name, to make your messages more engaging.
5. Scheduling and Sending Your WhatsApp Broadcast
After crafting your message, you can schedule your broadcast using Pabbly Chatflow. Decide whether to send the message immediately or at a scheduled time. If scheduling, select a future date and time.
Once scheduled, you can enable automatic retries for failed contacts. After confirming all settings, click “Add Broadcast” to finalize. You can later view the broadcast stats, including sent, delivered, and failed messages.
With these steps, you can effectively send personalized WhatsApp messages to your customers using Pabbly Chatflow. This integration streamlines your communication and enhances customer engagement.
In this tutorial, we explored how to use Pabbly Chatflow for WhatsApp integration, enabling personalized messaging for your customers. Following these steps allows for efficient communication and improved customer relationships.
