To start integrating Pabbly, Pabbly Chat Flow, Pabbly Plus, and Pabbly Chatbot, the first step is to access Pabbly Connect. Open your browser and navigate to the Pabbly Connect website.
Once on the site, sign up for an account or log in if you already have one. After logging in, you’ll be directed to the dashboard where you can begin setting up your integrations.
2. Setting Up Pabbly Chat Flow for Automation
After accessing Pabbly Connect, the next step is to set up Pabbly Chat Flow for your WhatsApp automation. Navigate to the Chat Flow section in the left sidebar.
- Select the “Broadcast” option from the menu.
- Create a new broadcast campaign for your membership offers.
- Name your broadcast, e.g., “Gym Membership Offers”.
This setup allows you to send messages to all your clients without the need for manual effort, streamlining your communication process.
3. Choosing Audience and Message Type in Pabbly Connect
Next, you need to choose the audience for your broadcast in Pabbly Connect. You can select an existing contact list or upload a CSV file containing your client details.
- Select “Contacts” from the sidebar.
- Add a new contact list if necessary.
- Filter out contacts you don’t want to include in the broadcast.
After selecting your audience, choose the type of message you want to send—either a regular message or a pre-approved template. This ensures your communication is relevant and engaging.
4. Scheduling and Sending Messages via Pabbly Connect
Once your message is ready, you can schedule it using Pabbly Connect. Choose whether you want to send it immediately or at a later date and time.
If you opt to schedule, select the desired date and time for your message to be sent. You can also enable automatic retries for any failed messages, ensuring your clients receive the information.
5. Monitoring Broadcast Results with Pabbly Connect
After your broadcast is sent, you can monitor the results using Pabbly Connect. Access the statistics by clicking on the “View Statistics” button.
This feature allows you to see which clients received the broadcast and which did not, providing valuable insights into your communication effectiveness.
This tutorial has detailed how to use Pabbly Connect for integrating Pabbly, Pabbly Chat Flow, Pabbly Plus, and Pabbly Chatbot. By following these steps, you can automate your messaging efficiently.
