1. Accessing Pabbly Connect for WhatsApp Automation
To automate your WhatsApp campaigns, start by accessing Pabbly Connect. Open your browser and navigate to the Pabbly Connect website. Create an account if you do not have one already. This tool will help you integrate various applications seamlessly.
Once logged in, you will see a user-friendly dashboard. From here, you can set up various automation workflows. The first step is to ensure your WhatsApp number is added to your account. This is crucial for sending messages through the Pabbly Chat Flow.
2. Setting Up Pabbly Chat Flow for Campaigns
After accessing Pabbly Connect, the next step is to set up Pabbly Chat Flow. Navigate to the left sidebar and click on “Broadcast”. This will take you to the WhatsApp broadcast page where you can create your campaign.
- Select “Broadcast Campaign” as the type of broadcast.
- Name your broadcast, for example, “Diwali Sale Offer”.
- Choose your audience by either uploading a CSV file or creating a contact list.
In this section, you can refine your audience by excluding contacts if needed. This helps in targeting the right customers for your promotional messages.
3. Creating a Contact List for Your Campaign
To send messages effectively, you need a well-defined contact list. Using Pabbly Connect, you can create a new contact list or upload an existing one in CSV format. Click on “Contacts” in the sidebar to manage your contacts.
To add contacts, simply click on the “Add Contact” button. You can upload multiple contacts at once by providing a CSV file with your customers’ details. Ensure that the file is formatted correctly to avoid any issues.
- Upload a CSV file containing your customer information.
- Create a new contact list by selecting “New Contact List”.
- Select multiple contact lists if needed.
After creating your contact list, you can move on to the next steps in your campaign setup, ensuring that your audience is ready to receive the broadcast.
4. Composing Your Message for the Broadcast
Now that your audience is set, it’s time to compose the message you want to send. In Pabbly Connect, you can choose to send a regular message or a pre-approved template message. Select the type of message under the broadcast settings.
If you opt for a template message, navigate to the “Templates” section in the sidebar. Here, you can create a new message template by clicking on “Add Template”. Ensure that your template is compliant with WhatsApp’s guidelines to avoid any issues.
After composing your message, you can preview it to ensure it appears as intended. If everything looks good, proceed to schedule or send the broadcast immediately.
5. Scheduling and Sending Your WhatsApp Broadcast
The final step in using Pabbly Connect for your WhatsApp campaign is scheduling the broadcast. You have the option to send it immediately or schedule it for a later date. If you choose to schedule, select the date and time for your broadcast.
Additionally, you can enable automatic retries for failed messages. This ensures that your broadcast reaches as many contacts as possible, even if some fail initially. Once everything is set, click on the “Create Broadcast” button to finalize your setup.
After scheduling, you can view the broadcast statistics to monitor its performance once it goes live. This feature allows you to track engagement and make necessary adjustments for future broadcasts.
In this tutorial, we explored how to use Pabbly Connect to automate your WhatsApp campaigns effectively. By integrating Pabbly Chat Flow and Pabbly Chatbot, you can streamline your communication with customers, ensuring timely delivery of promotions. Start using Pabbly Connect today to enhance your marketing strategies!
