To begin using Pabbly Connect for your WhatsApp broadcast, you first need to access the Pabbly platform. Open your web browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chat Flow homepage, where you can either sign up for a free account or log in if you already have one.
After logging in, you will see the dashboard, which includes all Pabbly applications. Click on “Access Now” under Pabbly Chat Flow to enter the dashboard. Here, you can manage your WhatsApp settings and begin setting up your broadcast.
2. Creating a WhatsApp Message Template in Pabbly
Before sending bulk WhatsApp messages, you need a message template. In your Pabbly Chat Flow dashboard, navigate to the “Templates” section. Here, you can create and manage your message templates. Ensure your template is approved by Meta to use it for broadcasting.
  • Click on the “Add Template” button to create a new template.
  • Draft your message and include any media you want to send.
  • Once done, submit it for approval.
After your template is approved, you can use it for your WhatsApp broadcast. Make sure to keep track of your templates and their statuses to ensure smooth communication with your customers.
3. Setting Up Your WhatsApp Broadcast with Pabbly Connect
To set up your WhatsApp broadcast, return to the Pabbly Chat Flow dashboard and click on the “Broadcast” section. Here, you can create a new broadcast campaign by clicking on the “Start Broadcast” button. Select “Broadcast Campaign” as the type and name your campaign.
Next, you will need to select your contact list. If you have customer data in a Google Sheet, download it as a CSV file and upload it to Pabbly Chat Flow. Once uploaded, you can select your contacts for the broadcast. Make sure to refine your audience by excluding any contacts you do not want to message.
4. Testing and Scheduling Your WhatsApp Broadcast
Once you have set up your broadcast details, it’s essential to test your message. Enter your WhatsApp number to send a test message. This allows you to ensure that everything looks perfect before sending it to your customers.
After testing, you can choose to send your broadcast immediately or schedule it for later. If scheduling, select the date and time, ensuring it’s set for the future. You can also enable automatic retries for any failed messages to ensure all your contacts receive the broadcast.
5. Monitoring Broadcast Results with Pabbly Connect
After your broadcast is sent, you can monitor its performance directly from the Pabbly Chat Flow dashboard. You will see statistics such as sent, delivered, read, pending, ignored, and failed messages.
If any messages fail to deliver, you can resend them easily using the “Resend” option. This feature allows you to ensure that your messages reach your customers without any hassle, maximizing your sales potential.
Using Pabbly Connect for WhatsApp broadcasting can significantly boost your sales by allowing you to reach your customers efficiently. By following the steps outlined, you can set up, test, and monitor your WhatsApp broadcasts seamlessly. Start leveraging this powerful tool today!
