1. Setting Up Pabbly Connect for WhatsApp Broadcasts
To boost sales fast using WhatsApp Mass Broadcasts, you first need to set up Pabbly Connect. Open your browser and go to chatflow.pabbly.com to create your account. After signing up, you’ll access the Pabbly Chat Flow dashboard.
Make sure to add your WhatsApp number to your Pabbly Chat Flow account. This step is crucial for sending broadcasts. If you need assistance, refer to the video linked in the description.
2. Creating a Broadcast in Pabbly Chat Flow
Once you’ve set up your account, the next step is creating a WhatsApp broadcast using Pabbly Connect. Navigate to the “Broadcast” option in the sidebar. This will direct you to the broadcast creation page.
  • Select the type of broadcast you want to create.
  • Name your broadcast, for example, “Jewelry Offers”.
  • Choose the audience from your contact list.
After naming your broadcast, you can upload a CSV file with your customer details if you haven’t created a contact list yet. This feature allows you to send messages to multiple clients efficiently.
3. Configuring Your Message for the Broadcast
With Pabbly Connect, you can configure your message for the broadcast. You can either use a template message or create a regular message. If you opt for a template, ensure it’s approved by Meta.
For a regular message, simply type your content in the provided field. You can also add images to enhance your message. A preview of your message will appear on the right side, allowing you to verify its appearance before sending.
  • Choose between template and regular message.
  • Add images to your message for better engagement.
After configuring your message, you can send a test broadcast to check how it looks. Enter your contact name and number to receive a trial message.
4. Scheduling and Sending Your Broadcast
In this section, you’ll learn how to schedule your broadcast using Pabbly Connect. You have the option to send your message immediately or schedule it for a later time. If you choose to schedule, select your desired date and time.
For instance, if you want to send a message on September 29, 2026, at 7:00 PM, set that in the scheduling options. By default, if you select any past date, the broadcast will be sent immediately.
Additionally, you can enable automatic retries for contacts that fail to receive the message. This feature ensures your broadcast reaches all intended recipients without manual checks.
5. Analyzing Your Broadcast Results with Pabbly Connect
After sending your broadcast via Pabbly Connect, monitoring its success is essential. You can view statistics on how many clients received, opened, or ignored your message. This data helps you understand the effectiveness of your campaigns.
To analyze your results, select the “View Statistics” option in the dashboard. Here, you will see a comprehensive report detailing the delivery status of your broadcast.
In summary, Pabbly Connect simplifies the process of sending WhatsApp Mass Broadcasts, allowing you to boost sales efficiently and effectively.
Using Pabbly Connect, you can easily boost sales fast through WhatsApp Mass Broadcasts. This tutorial covered how to set up, create, and analyze your broadcasts effectively. Leverage this powerful tool to enhance your marketing efforts.
