1. Access Pabbly Connect and Chat Flow
To begin boosting your ecommerce sales using WhatsApp Broadcast, you first need to access Pabbly Connect. Open your browser and navigate to pabbly.com/chatflow. This will take you to the Pabbly Chatbot homepage.
If you’re a new user, click on “تسجيل مجاناً” to sign up for a free trial. Existing users can simply log in. Once logged in, navigate to the “جميع تطبيقات بابلي” section to find all Pabbly applications, including Pabbly Chat Flow.
2. Integrate WhatsApp in Pabbly Chat Flow
After accessing Pabbly Chat Flow, you need to integrate your WhatsApp number. This is essential for sending broadcasts. If you haven’t linked your WhatsApp yet, refer to the tutorial available on the Pabbly YouTube channel for guidance.
Once your WhatsApp is linked, you can start using the broadcast feature. Click on the “البث” option in the menu. This will open the broadcast dashboard where you can view your broadcast statistics and create new broadcasts.
- Navigate to the “البث” section.
- Click on “إضافة بث” to create a new broadcast.
- Select the type of campaign you want to run.
Now that you are in the broadcast section, you can proceed to set up your broadcast campaign. Make sure to select the correct options for your audience to maximize engagement.
3. Create Your Broadcast Message
Creating an effective broadcast message is crucial for your ecommerce sales. Within Pabbly Connect, you can set up a template message that you intend to send to your customers. This template should convey your promotional offers clearly.
To create a new broadcast, you will need to fill in specific fields: campaign name, audience selection, and message type. If you have a CSV file with customer data, you can upload it here as well. Ensure that your message is compelling and includes any images or media that enhance its appeal.
- Fill in the campaign name (e.g., “تجارة إلكترونية جديدة”).
- Select your target audience from existing contacts or upload a CSV file.
- Choose whether to use a pre-approved template or create a new message.
Once your message is crafted, you can preview it on the right side of the screen to ensure it appears as expected before sending.
4. Test and Schedule Your Broadcast
Before sending your broadcast to all your contacts, it’s wise to test it. Use the option to send a test message to your own WhatsApp number to review how it looks. This is a critical step to ensure that your message is formatted correctly and conveys the intended message.
After testing, you can choose whether to send the broadcast immediately or schedule it for a later time. If scheduling, ensure you select a future date and time. This is crucial, as sending it at the wrong time can affect engagement.
- Click “إرسال رسالة اختبار” to check the message.
- Choose to send it now or schedule it for later.
- Set a specific date and time if scheduling.
Once confirmed, you will see your broadcast listed in the dashboard, where you can monitor its performance.
5. Monitor Broadcast Results
After your broadcast has been sent, you can monitor its effectiveness through the Pabbly Connect dashboard. Here, you’ll find statistics including messages sent, delivered, read, and any that failed to send.
This data is invaluable for understanding how your audience is responding to your promotions. You can also choose to resend messages to contacts that didn’t receive them initially, ensuring maximum outreach.
By leveraging these insights, you can refine your future broadcasts and improve your ecommerce sales strategy.
In conclusion, using Pabbly Connect for WhatsApp broadcasts is an effective strategy to boost ecommerce sales. By following these steps, you can streamline your communication with customers and enhance engagement.
