To begin integrating WhatsApp with your AI assistant, first, access Pabbly Connect. Open a new tab and visit the Pabbly Connect website. After signing in, you will be directed to the dashboard.
Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This is where you will set up the integration between WhatsApp and your AI assistant effectively.
2. Creating Your AI Assistant in Pabbly Connect
To create your AI assistant, navigate to the AI assistant section in Pabbly Connect. Click on ‘Add New AI Assistant’, and give it a name, such as “Drive Fruit Business Bot”. This will help you identify the assistant later.
  • Select the type as ‘AI Agent’.
  • Set the temperature to 0.5 for balanced responses.
  • Choose OpenAI as the AI to use and select the model as GPT-4.
After setting these parameters, save your assistant. This will allow it to respond to customer queries efficiently.
3. Configuring API in Pabbly Connect
Next, you need to configure the API settings in Pabbly Connect. Go to the API key section of your OpenAI account and generate a new key. This key is essential for your AI assistant to function properly.
Copy the generated API key and paste it into the designated field in Pabbly Connect. Click on the ‘Connect’ button to establish the link between your AI assistant and OpenAI. This connection is vital for your assistant to retrieve and process information.
4. Adding Knowledge Source for Your AI Assistant
The knowledge source is crucial for your AI assistant to provide accurate information. In Pabbly Connect, you can upload a document detailing your business, including products, prices, and policies.
  • Upload your business knowledge document.
  • Ensure it contains all relevant information for customer queries.
Once uploaded, your AI assistant will be equipped to answer questions based on the information provided in the document, enhancing customer interaction.
5. Finalizing Your Assistant’s Settings
To finalize your assistant’s settings in Pabbly Connect, adjust the interface and styling options to match your brand. You can customize the initial message, footer, and other elements to create a seamless user experience.
After completing the setup, toggle the activation button to enable your assistant. This will allow it to respond to customer inquiries automatically. Save your settings to ensure everything is configured correctly.
Using Pabbly Connect to integrate your AI assistant with WhatsApp can significantly enhance customer interaction. This step-by-step guide has detailed how to set up and configure your assistant effectively, ensuring it meets your business needs.
