1. Setting Up Pabbly Connect for Your Broadcast Campaign
To start using Pabbly Connect for your broadcast campaign, you need to access the Broadcast feature. This allows you to create group messaging campaigns easily and securely. Click on the “Add Broadcast” button to initiate a new campaign.
Once you click the button, you will be directed to a new page. Here, you can select the type of broadcast campaign you wish to create. Enter a campaign name, such as “Auto Care Service Offer,” which serves as your example. You can replace it with your specific offer.
2. Choosing an Audience and Contact List in Pabbly Connect
In this step, you’ll need to select your audience for the broadcast. Utilizing Pabbly Connect, you can either create a new contact list or upload an existing CSV file. A CSV file is a simple file format that allows you to store your contacts easily.
- You can create a new contact list directly in Pabbly Connect.
- Alternatively, upload an existing CSV file with your contacts.
- Ensure your CSV file is formatted correctly with first name, last name, and phone number.
For testing purposes, you can select the “Choose Existing Contact List” option. After selecting your contact list, you can refine your audience further to exclude contacts who have messaged you in the last 24 hours.
3. Creating Your Message Template with Pabbly Connect
Now that your audience is set, the next step involves creating your message template. This is crucial for your broadcast campaign. In Pabbly Connect, you can choose between an approved template message or a regular message.
To create an attractive WhatsApp template, you can utilize the templates feature in Pabbly Chat Flow. After selecting your template, you can add images and customize your message as needed. Once you have finalized your message, you can test it by entering a contact name and number.
4. Scheduling and Sending Your Broadcast with Pabbly Connect
After testing your message, you can schedule your broadcast. In Pabbly Connect, you can either send your message immediately or schedule it for a later date and time. For instance, you might want to send your message on November 26 at 5 PM.
Additionally, you can enable automatic retries for contacts that fail to receive the message. This feature is powered by Pabbly Shortflow, which will resend the message automatically based on your specified parameters.
5. Viewing Broadcast Stats and Reports in Pabbly Connect
Once your broadcast is scheduled, you can monitor its performance. In Pabbly Connect, you can click on the “View Stats” button to check the status of your broadcast campaign. This feature allows you to export reports as needed.
These insights will help you refine future campaigns and improve your messaging strategies. Remember, Pabbly Connect not only facilitates broadcast campaigns but also allows you to create chatbots and automate various tasks efficiently.
In this tutorial, we explored how to effectively use Pabbly Connect for creating and managing broadcast campaigns. By integrating various applications, you can streamline your messaging process and enhance audience engagement.
