1. Accessing Pabbly Chatflow to Create Your AI Assistant
To start creating your AI assistant, first access Pabbly Chatflow by typing ‘pabli.com/chatflow’ into your browser. This platform allows you to build your assistant without any coding skills.
Once on the Pabbly Chatflow website, you can sign up for a free account. This is crucial as it sets the foundation for automating customer responses through your AI assistant.
2. Configuring Your AI Assistant in Pabbly Chatflow
After signing up, navigate to the AI Assistant page in Pabbly Chatflow. Here, you can begin setting up your assistant. Ensure your WhatsApp number is linked to your Pabbly Chatflow account for seamless integration.
  • Select the AI Instructions tab.
  • Choose the AI Agent instruction type.
  • Set the temperature to define the creativity of responses.
This setup allows you to customize how your AI assistant interacts with customers, making it more personalized and effective.
3. AI Settings and Configuration in Pabbly Chatflow
Once you have configured the basic settings, navigate to the AI Settings section in Pabbly Chatflow. Here, you can modify various settings, such as enabling header and footer messages.
Additionally, you can enter stop keywords that will halt the assistant’s responses when triggered. This is essential for maintaining control over the conversation flow.
  • Set retry attempts for the assistant’s responses.
  • Define fallback messages for when the assistant cannot respond.
These configurations ensure that your AI assistant is reliable and can handle various situations effectively.
4. Uploading Your Knowledge Base in Pabbly Chatflow
To enhance your AI assistant’s capabilities, you must upload a knowledge base. This is done in Pabbly Chatflow by providing detailed information about your business.
Prepare your knowledge base in .txt or .pdf format. Once ready, navigate to the knowledge base upload section and insert your file. This file should contain all relevant details about your services, pricing, and frequently asked questions.
  • Make sure to include service descriptions.
  • Add any appointment processes and payment options.
Having a well-structured knowledge base allows your AI assistant to provide accurate responses to customer queries.
5. Finalizing Your AI Assistant in Pabbly Chatflow
After configuring all settings and uploading your knowledge base, you can finalize your AI assistant in Pabbly Chatflow. This involves setting up the chat interface and customizing the appearance.
In the chat interface tab, change the chat window title to something relevant to your business. For example, you might use ‘Happy Paws Veterinary Clinic’. You can also customize the subtitle and initial messages that users will see.
  • Enable or disable the “Powered by Pabbly” label.
  • Set the footer text and links as needed.
Finally, save your settings and embed the assistant on your website using the provided code. This allows your customers to interact with your AI assistant seamlessly.
Creating your own AI assistant using Pabbly Chatflow is a straightforward process that can be completed in just 10 minutes. By following these steps, you can automate customer responses effectively and enhance your business operations.
