1. Accessing Pabbly Chatflow for WhatsApp AI Agent
To create a WhatsApp AI agent, you first need to access Pabbly Chatflow. This platform allows you to build automated agents without any coding skills. Start by logging into your Pabbly Chatflow account.
Once logged in, navigate to the AI Assistant feature. This is where you can create your WhatsApp AI agent easily. Click on the ‘Add AI Assistant’ button to begin the setup process.
2. Setting Up Your AI Agent in Pabbly Chatflow
After clicking ‘Add AI Assistant’, you will be prompted to name your agent. For instance, you might name it ‘E-commerce Sales AI Assistant’. This name can be customized based on your business type.
  • Click the ‘Add AI Assistant’ button.
  • Enter a name for your AI agent.
  • Select the instruction type as ‘AI Agent’.
After naming your agent, you will see a page where you need to select the instruction type. This instruction guides the AI agent on how to respond to customer queries. Customize these instructions based on your needs for personalized responses.
3. Configuring AI Settings in Pabbly Chatflow
Next, you will configure the AI settings in Pabbly Chatflow. This includes setting the temperature, which controls the creativity of the responses. A lower temperature results in more stable replies, while a higher temperature allows for more creative responses.
Choose an AI provider, such as ‘OpenAI’, and select the AI version you wish to use, for example, GPT 4.2. This version can handle image-based queries effectively. After making these selections, you will need to enter your API Key to connect with OpenAI.
  • Select ‘OpenAI’ as your AI provider.
  • Choose the AI version (e.g., GPT 4.2).
  • Enter your OpenAI API Key for integration.
Once you have entered the API Key, click the ‘Connect’ button. You will receive a message confirming that the API Key has been saved successfully, indicating that the connection has been established.
4. Uploading Knowledge Base in Pabbly Chatflow
The next step is to upload your knowledge base file in Pabbly Chatflow. This file serves as a repository of information that your AI agent will use to provide accurate responses. You can create this file using Google Docs or any application that supports PDF or text formats.
Ensure that your knowledge base file is under 90 MB. To upload, click on the ‘Add New File’ option and select your prepared file from your gallery. After selecting, click the ‘Insert’ button to upload the file.
  • Create a knowledge base file using Google Docs.
  • Ensure the file size is less than 90 MB.
  • Upload the file by clicking ‘Add New File’.
Once uploaded, your AI agent will be able to train on this data, allowing it to provide relevant answers based on your business information.
5. Finalizing Your AI Agent in Pabbly Chatflow
Finally, you will customize the interface of your AI agent in Pabbly Chatflow. You can set the title and subtitle that customers will see. For example, you might set the title as ‘Shop is Online Store’. This title will appear prominently in customer interactions.
After setting the title, enable the toggle for the AI Assistant to activate it. Click the ‘Save AI Assistant’ button to finalize your setup. Your WhatsApp AI agent is now ready to handle customer queries automatically.
  • Set the title and subtitle for your AI agent.
  • Enable the toggle to activate the AI Assistant.
  • Click ‘Save AI Assistant’ to complete the process.
Your WhatsApp AI agent is now fully functional, ready to respond to customer inquiries around the clock. You can also embed this AI agent on your website by clicking the ‘Embed’ button to obtain the code.
Creating a WhatsApp AI agent without coding is made easy with Pabbly Chatflow. This tutorial guides you through every step, ensuring your agent is ready for customer interactions. Start using Pabbly Chatflow today for effective automation!
