1. Accessing Pabbly Chatflow for WhatsApp Automation
To begin automating your clinic’s WhatsApp communications, you need to access Pabbly Chatflow. Start by navigating to www.pabbly.com/chatflow in your web browser. This platform provides the essential tools for seamless integration with WhatsApp.
Once on the website, log in to your existing account or sign up for a free trial to explore the features. The free trial offers 100 credits monthly, allowing you to test the capabilities of Pabbly Chatflow before committing to a subscription.
2. Setting Up WhatsApp in Pabbly Chatflow
After logging into Pabbly Chatflow, the next step is to set up your WhatsApp account. Click on the “Add WhatsApp Number” option in the dashboard. You can connect your WhatsApp account either through the preferred method or by using a manual token.
- Select the preferred method for WhatsApp connection.
- If needed, refer to the detailed video in the description for step-by-step guidance.
Once connected, you can view the credits allotted and consumed. This setup is crucial for enabling the WhatsApp automation features offered by Pabbly Chatflow.
3. Creating Your AI Assistant in Pabbly Chatflow
The heart of the automation process lies in creating your AI assistant. Click on the “AI Assistant” option on the left sidebar to begin. Here, you will name your assistant, such as “Best WhatsApp Automation Tool for Clinics and Hospitals,” and select the instruction type as AI agent.
Next, configure the AI settings, including creativity level and the AI model. For instance, you might set the creativity level to 0.7 and choose OpenAI as the AI to use. Enter your API token to connect with OpenAI, ensuring your assistant can generate responses effectively.
- Enable header and footer messages for user interactions.
- Set up stop keywords to manage user queries effectively.
- Upload a knowledge base file to enhance your assistant’s responses.
This comprehensive setup ensures that your AI assistant is ready to handle various queries from users, making Pabbly Chatflow an invaluable tool for your clinic’s automation needs.
4. Assigning Your AI Assistant in Pabbly Chatflow
Once your AI assistant is created, it’s essential to assign it to the appropriate contacts. Navigate to the “Inbox” section and select the chat where you want to apply the AI assistant. Toggle the option to choose your newly created AI assistant and save the settings.
For broader applications, you can assign the AI assistant to a group or all contacts. Access the “Settings” menu, then navigate to “Inbox Settings”. Enable AI auto-replies and select the desired lists or contacts for the assistant.
- Choose the specific AI assistant for each contact group.
- Save the rules to ensure the AI assistant responds to inquiries automatically.
This step ensures that your clinic can efficiently handle multiple inquiries through Pabbly Chatflow, enhancing customer service and operational efficiency.
5. Testing Your AI Assistant with Pabbly Chatflow
After setting up and assigning your AI assistant, it’s time to test its functionality. Send a message through WhatsApp, such as “Can I check consultation fees and hospital department?” and observe the response from your AI assistant.
The assistant should reply with relevant information, confirming that it can provide details about consultation fees and departments. You can further test by asking about appointment requests or available treatments to ensure comprehensive responses.
Successful replies indicate that your AI assistant is functioning correctly, showcasing the power of Pabbly Chatflow in automating communication for your clinic.
In summary, using Pabbly Chatflow allows you to automate WhatsApp communications effectively for your clinic. By following the steps outlined, you can create an AI assistant that enhances customer interaction and streamlines your operations.
