1. Accessing Pabbly Chatflow for WhatsApp Automation
To create WhatsApp automation for your agency, start by accessing Pabbly Chatflow. Open your browser and navigate to www.pabbly.com/chatflow. This platform is essential for integrating various applications seamlessly.
Once on the site, you’ll have two options: “Sign In” for existing users or “Sign Up for Free” for new users. Signing up grants you 100 free credits monthly, allowing you to explore the features of Pabbly Chatflow before committing.
2. Setting Up WhatsApp in Pabbly Chatflow
After signing in, navigate to the dashboard of Pabbly Chatflow. Here, you’ll see your credit status and options to add your WhatsApp number. Click on “Add WhatsApp Number” to begin the integration process.
- Select “WhatsApp Connect” as your preferred method.
- Alternatively, use a manual token if necessary.
For detailed steps on connecting your WhatsApp, refer to the provided resources. This is crucial for enabling your WhatsApp automation to function correctly through Pabbly Chatflow.
3. Creating Your AI Assistant in Pabbly Chatflow
To set up an AI assistant, click on the “AI Assistant” option in the left sidebar of Pabbly Chatflow. You can name your assistant something like “Best WhatsApp Automation Software for Agencies” and proceed to configure its settings.
In the settings, you’ll define the AI instructions and adjust parameters like creativity level. Set the temperature to 0.7 for a balance between creativity and focus. Ensure you have your API key ready for integration with OpenAI, which is necessary for the assistant to function.
- Toggle on the header and footer messages for enhanced interaction.
- Define a stop keyword for user control over the conversation.
After configuring the assistant, save your settings to ensure everything is stored correctly in Pabbly Chatflow.
4. Integrating Knowledge Base into Pabbly Chatflow
Next, you’ll need to upload a knowledge base that your AI assistant can reference. In Pabbly Chatflow, select “Upload File” under the knowledge source section. This document should contain all relevant information about your agency.
Upload your file, ensuring it is in .txt or PDF format. If your document includes images, keep the page count under 10. This knowledge base is vital for providing accurate answers to user inquiries.
- Ensure the document outlines services, pricing, and company details.
- After uploading, confirm the AI assistant can access this information.
Once uploaded, your assistant will be equipped to handle inquiries based on the knowledge base, enhancing user experience through Pabbly Chatflow.
5. Assigning Your AI Assistant to Contacts in Pabbly Chatflow
Finally, you can assign your AI assistant to specific contacts or groups. In Pabbly Chatflow, navigate to the inbox settings. Enable AI order reply settings and select the AI assistant you created.
For broader applications, you can assign this assistant to multiple contacts or an entire list. This streamlines communication and ensures all inquiries are handled efficiently.
- Choose the appropriate AI assistant for each contact list.
- Save your settings to activate the assistant for those contacts.
With your assistant assigned, you’re ready to automate conversations effectively through Pabbly Chatflow.
In this tutorial, we explored how to create WhatsApp automation using Pabbly Chatflow. By accessing the platform, setting up your assistant, and integrating a knowledge base, you can enhance your agency’s communication and efficiency.
