To begin automating your WhatsApp marketing, you need to access Pabbly Connect. Start by navigating to the Pabbly website and signing in with your credentials.
Once logged in, you’ll land on the Pabbly dashboard. Here, you can easily manage your integrations. Click on “Create New Workflow” to start setting up your WhatsApp automation process.
2. Setting Up a WhatsApp Assistant with Pabbly Connect
With Pabbly Connect, you can create a WhatsApp assistant effortlessly. Click on “Add Assistant” and enter a name for your assistant, such as “Real Estate Agent”.
- Choose the type of agent you want to create (e.g., Sales Agent).
- Set the temperature for responses to customize the creativity of replies.
- Select the AI platform, like OpenAI, for your assistant’s functionality.
After configuring these settings, save your assistant. This assistant will now handle customer queries automatically through WhatsApp.
3. Integrating Knowledge Source in Pabbly Connect
To enhance your assistant’s responses, integrate a knowledge source with Pabbly Connect. This involves uploading a PDF or text file containing your business details.
- Prepare a PDF file with comprehensive information about your business.
- Upload this file in the “Knowledge Source” section of your assistant settings.
- This file will guide the assistant in providing accurate responses based on customer inquiries.
By integrating this knowledge source, your WhatsApp assistant will be equipped to handle queries more effectively.
4. Connecting Your WhatsApp Business Number via Pabbly Connect
To connect your WhatsApp Business number, go to the “Add WhatsApp Number” option in Pabbly Connect. You can choose between manual token connection or preferred method.
Follow the on-screen prompts to complete the connection. Ensure you have your WhatsApp Business account ready for integration. This step is crucial for enabling your assistant to send and receive messages.
5. Automating Responses Using Pabbly Connect
Once your assistant and WhatsApp number are set up, you can automate responses. Go to the settings and enable the auto-reply feature within Pabbly Connect.
Choose the assistant you created earlier and assign it to specific contacts or all contacts. This way, any incoming message will be automatically replied to by your assistant, ensuring prompt customer service.
In this tutorial, we explored how to use Pabbly Connect to automate WhatsApp marketing. By integrating WhatsApp with Pabbly Connect, you can create an efficient assistant that enhances customer engagement and service.
