1. Accessing Pabbly Chatflow for WhatsApp Automation
To start using Pabbly Chatflow, you need to visit the official website. Enter www.pabbly.com/chatflow in your browser. This is where you will set up your AI WhatsApp automation for your e-commerce business.
Once on the site, sign in to your account. If you’re a new user, you can sign up for free and receive 100 credits monthly. Existing users can simply click on the “Sign In” button located at the top right corner.
2. Setting Up Your WhatsApp in Pabbly Chatflow
After logging into Pabbly Chatflow, you’ll need to connect your WhatsApp number. Click on the “WhatsApp Connect” option to initiate this process. This integration is crucial for your AI assistant to interact with customers via WhatsApp.
- Choose the preferred method for connecting WhatsApp.
- You can also opt for a manual token if preferred.
- For detailed steps, refer to the video tutorial provided.
Once your WhatsApp is connected, you can proceed to create your AI assistant within Pabbly Chatflow, which will handle customer queries efficiently.
3. Creating Your AI Assistant in Pabbly Chatflow
To create an AI assistant, navigate to the “AI Assistant” option in Pabbly Chatflow. Click on “Add Assistant” and name it according to your business, such as “E-commerce Business”. This assistant will manage customer interactions through WhatsApp.
Set the instruction type for your AI assistant to “AI Agent”. This allows the assistant to understand and respond to customer queries effectively. You can adjust the creativity level of responses by setting the temperature between 0 and 1, with 0 being more focused and 1 being more creative.
- Select the AI model, such as GPT5 Mini.
- Input your OpenAI API key to enable functionality.
- Toggle on essential settings like header messages and stop keywords.
Once these settings are adjusted, your AI assistant will be ready to handle various customer queries effectively through WhatsApp.
4. Configuring Knowledge Source for Your AI Assistant
In Pabbly Chatflow, it’s essential to provide a robust knowledge base for your AI assistant. This is where you can upload files containing information about your products and services. Click on “Upload File” to add relevant documents.
Ensure that the uploaded file contains detailed information about your business, including product descriptions, services offered, and contact details. This knowledge source will empower your AI assistant to provide accurate responses to customer inquiries.
- Select the file you want to upload and insert it into the system.
- Make sure the file is in an appropriate format, such as PDF.
- Review the content to ensure it aligns with customer needs.
With a well-configured knowledge source, your AI assistant will be able to assist customers effectively by providing accurate information based on their queries.
5. Assigning Your AI Assistant in Pabbly Chatflow
Once your AI assistant is created, you can assign it to specific contacts or groups in Pabbly Chatflow. Navigate to the “Inbox” section to manage your contacts and assign the AI assistant accordingly.
To assign the assistant, select the chat where you want to implement the AI assistant. Then save the settings to ensure the assistant is linked to that particular chat. This allows for efficient handling of customer queries.
- Enable AI auto-replies for a more streamlined process.
- Select the list of contacts for which the AI assistant will respond.
- Save your settings to ensure the assistant is active.
This setup allows your AI assistant to manage customer interactions effectively, reducing manual effort and ensuring timely responses to inquiries.
Using Pabbly Chatflow, you can easily create an AI WhatsApp assistant that enhances customer interactions for your e-commerce business. This detailed tutorial guides you through accessing Pabbly Chatflow, setting up your WhatsApp, creating your AI assistant, configuring its knowledge source, and assigning it to contacts. Automate your customer service today!
