To integrate WhatsApp with Pabbly, first access Pabbly Connect by visiting chatflow.pabbly.com. This platform allows you to automate messaging processes seamlessly.
After signing up for an account, you will be directed to the Pabbly dashboard. Here, you need to add your WhatsApp number to begin the integration process. This step is crucial for sending bulk messages effectively.
2. Setting Up Broadcasts in Pabbly Connect
Once you have your WhatsApp number added, the next step is to set up a broadcast. In the left menu, select the “Broadcast” option. This feature allows you to send messages to multiple contacts simultaneously.
- Choose the type of broadcast, such as “Broadcast Campaign”.
- Assign a name to your broadcast, e.g., “Property Offers”.
- Select your audience from existing contact lists or upload a CSV file.
After setting up your broadcast details, ensure that you select the correct audience. You can refine your audience by excluding contacts who should not receive the message.
3. Creating Message Templates in Pabbly Chatflow
In this section, you will create message templates necessary for your broadcast. Using Pabbly Chatflow, you can design messages that comply with WhatsApp’s guidelines.
To create a template, navigate to the “Templates” section in the left menu. Here, you can select a pre-approved template or create a new one. Ensure the template is approved to avoid blocking your WhatsApp number.
- Select a template from the list or create a new one.
- Add images or quick reply buttons as needed.
- Preview your message to ensure it appears correctly.
Once your template is ready, select it for your broadcast. This ensures that your messages are consistent and professional.
4. Scheduling Your Broadcast with Pabbly Connect
After preparing your message, it’s time to schedule your broadcast. In Pabbly Connect, you have the option to send messages instantly or schedule them for later.
If you choose to schedule, select the option “Yes schedule for later” and choose your desired date and time. This allows you to plan your messaging strategy effectively.
Additionally, you can enable the feature “Automatically retry your failed contacts” to ensure that messages are resent to any contacts that failed to receive them. This is essential for maximizing outreach.
5. Monitoring Broadcast Results in Pabbly Connect
Once your broadcast is scheduled, you can monitor its performance. After the broadcast goes live, you can view statistics by selecting the “View stats” button in Pabbly Connect.
This feature provides insights into how many messages were delivered, opened, and responded to. Understanding these metrics is crucial for refining your future campaigns.
By leveraging these analytics, you can enhance your messaging strategies and ensure successful communication with your audience.
In this tutorial, we explored how to use Pabbly Connect to integrate WhatsApp for bulk messaging. By following these steps, you can effectively manage your communications without risking your business number.
