To start automating Instagram posts to Discord, you need to access Pabbly Connect. If you’re a new user, open your browser and search for pabbly.com/connect to reach the landing page.
Once on the page, click on the “Sign Up for Free” button located in the top right corner. This will allow you to create an account and start your free trial of Pabbly Connect. If you enjoy the service, you can later opt for a subscription plan.
After logging into Pabbly Connect, navigate to the workflow builder. This is where you will set up the automation process. Click on the “Add Trigger” button to begin.
For the trigger application, search for Instagram and select “Instagram for Business”. Choose the event “New Media Posted in My Account” and click on “Connect”. If you’ve previously connected Instagram with Pabbly Connect, you can select the existing connection; otherwise, add a new connection by logging into your Instagram account.
3. Setting Up Discord Integration with Pabbly Connect
Now that your Instagram account is connected, you need to set up Discord as the action step. Click on “Add New Action Step” and select Discord.
For the event, choose “Send Channel Message” and click on “Connect”. Similar to Instagram, if you have an existing connection, select it; otherwise, create a new connection by logging into your Discord account.
  • Ensure your Discord account is logged in before proceeding.
  • Select the correct server where the message will be sent.
  • Authorize the connection to complete the setup.
After successfully connecting Discord, you will need to set up a webhook to send messages. Create a new webhook in your Discord channel settings, copy the webhook URL, and paste it into Pabbly Connect.
4. Mapping Data for Dynamic Messages
In this step, you will create the message that will be sent to Discord whenever a new Instagram post is made. Use the data received from the Instagram trigger to map the relevant post details into the message template.
For the message text, you can use mapping to insert dynamic data. For example, include the post caption and a link to the post. To do this, enter the message template and use the mapping feature to pull in the Instagram post details.
  • Copy the permalink and other relevant details from the Instagram post.
  • Ensure the message is formatted to include all necessary information for your Discord audience.
After setting up the message, click on the “Save and Send Test Request” button to confirm that the message is sent successfully to Discord.
5. Finalizing Your Instagram to Discord Automation
Once you have tested the setup and confirmed that the message is sent to Discord, your automation process is complete. Every time you post on Instagram, Pabbly Connect will check for new posts every 10 minutes and send updates to your Discord channel.
This automated workflow not only saves time but also enhances engagement with your audience by keeping them informed about new content. If you want to adjust the frequency of checks, you can modify the trigger settings in Pabbly Connect.
With this setup, you can ensure that your followers on Discord are always updated with your latest Instagram posts, enhancing your online presence and engagement.
In this tutorial, we explored how to automate Instagram posts to Discord using Pabbly Connect. By following these steps, you can streamline your social media management and keep your audience engaged effortlessly.
