1. Accessing Pabbly Connect for WooCommerce Integration
To begin the integration process, first access Pabbly Connect by visiting pabbly.com. This platform is essential for automating your WooCommerce product sharing on social media.
Once on the website, sign in to your existing account or create a new one. By signing up, you get 100 free tasks every month, allowing you to explore the platform’s features. After logging in, navigate to the Pabbly Connect dashboard where you can manage your workflows.
In this section, you will create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button and name your workflow, such as “Automatically Share New WooCommerce Products to Social Media”. Select a folder for better organization.
  • Click on the ‘Create’ button to initiate the workflow.
  • Choose WooCommerce as your trigger application.
  • Set the trigger event to “New Product Created”.
After setting your trigger, you will connect Pabbly Connect with WooCommerce using the webhook URL provided. This URL acts as the bridge for communication between the two platforms.
3. Configuring WooCommerce for Webhook Integration
Next, configure your WooCommerce settings to complete the integration with Pabbly Connect. Navigate to WooCommerce settings, then go to the ‘Advanced’ tab where you will find the “Webhooks” option.
Click on “Add Webhook” and fill in the necessary details:
  • Name: Share Product
  • Status: Active
  • Topic: Product Created
  • Delivery URL: Paste the webhook URL from Pabbly Connect
Once you save the webhook, this setup will allow WooCommerce to send data to Pabbly Connect whenever a new product is created.
4. Testing the Webhook Response in Pabbly Connect
After setting up the webhook, it’s time to test the connection within Pabbly Connect. Go back to your workflow and click on “Recapture Webhook Response”. This will start the process of waiting for a response from WooCommerce.
To generate a test response, add a new product in WooCommerce. Fill in the product details such as name, description, and price, then click on “Publish”. Once published, check the Pabbly Connect dashboard to see if the webhook response was captured successfully.
Here’s what you should look for in the response:
  • Product Name
  • Product Description
  • Product Image Link
Once you confirm the response is correct, you can proceed to the next step in your automation workflow.
5. Posting New Products to Facebook Using Pabbly Connect
Now that you have successfully captured the webhook response, you can set up the action to post on Facebook through Pabbly Connect. Choose Facebook as your action application and select the event “Create Page Post”.
Connect your Facebook account to Pabbly Connect by following the prompts. Select the Facebook page where you want to post your new product. In the message field, map the response data from WooCommerce, including the product name and permalink.
Finally, save the workflow and send a test request to ensure everything is set up correctly. Once the test is successful, your new WooCommerce products will automatically be shared on your selected social media platforms.
In this tutorial, we explored how to use Pabbly Connect to automate sharing new products from WooCommerce to social media platforms like Facebook. By following the steps outlined, you can streamline your product announcements and enhance your online presence.
